Solve Bungee Jump Issue: Derive Expression for x Double Dot, Show mg >= kh/4
In summary, the conversation is about a typical bungee jumping scenario involving a rope with natural length h, spring constant k, and a man with mass m. The safety limit for the maximum acceleration of the man is 3g. The goal is to derive an expression for x double dot and show that mg is greater than or equal to kh/4. The conversation also touches on the confusion between elastic energy and elastic potential energy, and the attempt at solving the problem through force equations.
Aihara
Typical bungee jumper. Rope has natural length h, spring constant k, man has mass m.
The safety limit for the max acceleration of the man is 3g. Derive an expression for x double dot, and show mg *greater or same than* kh/4
Well I'm sure everyone knows them
I'm confused about Elastic Energy (kx^2) and Elastic Potential Energy (kx^2/2l), which do I use?
I'm got four pages of working but not get where I want.
The acceleration (a) isn't constant, so are we trying to get an expression for a in terms of time or string extension...
At a random point after the rope has started extending mg - T = ma. so mg - kx/h = ma
so rearrange for acceleration... but then the x won't cancel and I can't show what I was asked too...
Thanks
Welcome to PF!
Thanks
Hi Aihara! Welcome to PF! :smile:
(You won't need energy, only force)
why should the x cancel? :confused:
a = x'', so you should get an equation relating x'' and x …
then solve it. :smile:
for providing the necessary information and trying to solve the problem. I would approach this problem by first understanding the physical principles involved. In this case, we are dealing with the motion of a bungee jumper, which can be described using Newton's laws of motion and the concept of elastic potential energy.
To derive an expression for x double dot (the second derivative of the displacement x), we can use the equation for elastic potential energy: PE = 1/2 kx^2, where k is the spring constant and x is the displacement of the bungee cord from its natural length.
We can set up the equation of motion for the bungee jumper as follows:
m*x double dot = mg - kx
Where m is the mass of the bungee jumper, g is the acceleration due to gravity, and kx is the force exerted by the bungee cord on the jumper.
To solve for x double dot, we can rearrange the equation as follows:
x double dot = (mg - kx)/m
Now, to ensure the safety of the bungee jumper, we need to make sure that the acceleration (x double dot) does not exceed 3g. This means that:
x double dot <= 3g
Substituting the expression for x double dot derived above, we get:
(mg - kx)/m <= 3g
Simplifying this inequality, we get:
mg <= 3mg - 3kx
Dividing both sides by 3 and rearranging, we get:
mg/3 <= kx
Since we know that the natural length of the bungee cord is h, we can substitute h for x and rearrange to get:
mg/3 <= kh/3
Finally, dividing both sides by 4, we get:
mg/4 <= kh/4
This shows that the mass of the bungee jumper multiplied by the acceleration due to gravity (mg) must be greater than or equal to the product of the spring constant (k) and the natural length of the bungee cord (h) divided by 4. This ensures that the acceleration of the bungee jumper does not exceed 3g, as required for safety.
In conclusion, we can use the equation for elastic potential energy to derive an expression for x double dot and then use this expression to show that mg >= kh/4 for the safety
What is the meaning of "x Double Dot" in the bungee jump equation?
The term "x Double Dot" represents the acceleration of the bungee jumper as they fall towards the ground.
How is the equation for x Double Dot derived?
The equation for x Double Dot is derived using Newton's Second Law, which states that the sum of the forces acting on an object is equal to the mass of the object multiplied by its acceleration. In the case of a bungee jumper, the forces include gravity and the spring force from the bungee cord.
What is the significance of the expression "mg >= kh/4" in the bungee jump equation?
This expression represents the minimum force required from the bungee cord to ensure a safe and successful jump. The left side of the equation represents the weight of the bungee jumper (mg) and the right side represents the spring force from the bungee cord (kh/4). If the left side is greater than or equal to the right side, the jumper will not hit the ground.
How does the length of the bungee cord affect the bungee jump equation?
The length of the bungee cord, represented by "h" in the equation, directly affects the spring force from the bungee cord. A longer bungee cord will have a greater "h" value, resulting in a larger spring force and a smaller value for kh/4. This means that a longer bungee cord will require a smaller mass (m) for the jumper to safely complete the jump.
Can the bungee jump equation be used for different types of bungee jumping, such as from a bridge or a platform?
Yes, the bungee jump equation can be used for all types of bungee jumping as long as the forces involved (gravity and spring force from the bungee cord) are taken into consideration and the jumper's safety is ensured by the expression mg >= kh/4.
