Bungy jump problem
  • Thread starter ff93
You go bungee jumping from a bridge that is 65m high, the bungee cord has an unstretched length of 32m and a spring constant of k=107 N/m
You have a mass of 75kg.
Question: what is the acceleration at the bottom, closest to the ground?
I`ve tried to use 1/2kA2=1/2mx+1/2kx2
but it doesn´t seem to work for me :(
please help, I´m not asking for U to solve it but at least give me a couple of hints!!
Answers and Replies
Doc Al
Mentor
45,017
1,290
Start by figuring out where the lowest point is. Use conservation of energy.
should I use mgh=1/2kx2?
x as how far it stretches from 32m?
and then should I use F=-kx => F=ma and solve out a?
Doc Al
Mentor
45,017
1,290
Yes. Hint: Express h in terms of x. (Measure gravitational PE from the lowest point.)
you mean mg(x+32)=1/2kx2?
should I then continue with F=-kx => F=ma solve out a?
Doc Al
Mentor
45,017
1,290
Exactly.
Be sure to include all forces when applying F=ma.
mg(x+32)=1/2kx2 gives two answers but I can throw away the negative one, right?
then I used F=-kx+mg => a= (-kx+mg)/m
is that right?
Doc Al
Mentor
45,017
1,290
Right.
is that right?
Yes, that's fine.
Don't get hung up with signs. You have an upward force of magnitude kx and downward force of magnitude mg. Which direction will the acceleration be in at the lowest point?
the direction will be "up",negative
right?
Doc Al
Mentor
45,017
1,290
right?
Yes, the acceleration will be up. Which you happen to call negative. I suspect that they only care about the magnitude of that acceleration.
thank you for the help!:smile:
Related Threads on Bungy jump problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
14K
  • Last Post
  • Last Post
