Calculating Lung Capacity in Liters: Freshwater Buoyancy Volume Question
  • Thread starter NY152
  • Tags
    Volume
In summary, the 69.5 kg man floats with a volume of 1.25 liters above water when his lungs are empty and 4.75% of his volume above water when his lungs are full.
NY152
25
A 69.5 kg man floats in freshwater with 2.95% of his volume above water when his lungs are empty, and 4.75% of his volume above water when his lungs are full. Calculate the volume of air, in liters, that he inhales (this is called his lung capacity). Neglect the weight of air in his lungs.
d=m/v
freshwater: d=1000 kg/m^3
From the given information, there's a 1.8% increase in volume. I'm just not sure where to start given the information above.
You should be able to determine the man's volume for both cases. Start by considering the volume of water he displaces in order to float.
Okay so I did ((69.5 kg/1000 kg/m^3)*(4.75/100))-((69.5/1000 kg/m^3)(2.95/100))= .00125 m^3 then converted that to liters which is 1.25 Liters. The homework system says "it looks like you may have confused the denominator and the numerator, check your algebra" Not sure where I'm going wrong here though...
You've found the difference between 4.75% of the displaced water and 2.95% of the displaced water. That's not what you're looking for. The displaced water volume is constant and smaller than the man's volume. You need to find the two volumes of the man.
By the way, save yourself a heap of typing and just assign a variable name to repeated quantities. Call the volume of water displaced vw, for example.
Likes NY152
Oh okay, so I'd do the same sort of math setup but use 95.25% and 97.05% instead?
No. Let's concentrate on one of the volumes for the man first.
You've correctly determined that he displaces a volume of water ##V_w = M/ρ##, where M is his mass and ρ the density of water. That is also the amount of his volume that is below water (since it's displacing the water). Let's call the man's total volume for the first case (the 2.95% above water case) ##V_o##. What would be the volume above water (in symbols, no numbers yet)?
What is buoyancy volume?
Buoyancy volume refers to the volume of fluid that an object displaces when submerged in a fluid. It is a measure of the upward force, or buoyant force, that a fluid exerts on an object.
How is buoyancy volume calculated?
Buoyancy volume can be calculated by dividing the weight of the object by the density of the fluid. The resulting value is the volume of fluid that is displaced by the object.
What factors affect buoyancy volume?
The buoyancy volume of an object is affected by its density, shape, and size. Objects that are less dense than the fluid they are submerged in will have a greater buoyancy volume, while objects that are more dense will have a smaller buoyancy volume.
Why is buoyancy volume important?
Buoyancy volume is important in understanding the behavior of objects in fluids, such as ships and submarines in water. It also plays a role in determining the stability and floating ability of objects.
How is buoyancy volume related to Archimedes' principle?
Buoyancy volume is directly related to Archimedes' principle, which states that the buoyant force on an object is equal to the weight of the fluid that is displaced by the object. The greater the buoyancy volume of an object, the greater the buoyant force acting on it.
9K
10K
