1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Buoyancy and Archimedes' Principle
  1. Dec 5, 2009 #1
    Because gasoline is less dense than water, drums containing gasoline will float in water. Suppose a 260 L steel drum is completely full of gasoline.
    What total volume of steel can be used in making the drum if the gasoline-filled drum is to float in fresh water?
    2. Relevant equations
    P=[tex]\rho[/tex]*V*g
    Archimedes' principle - the buoyant force on an object immersed in a fluid is equal to the weight of the fluid displaced by that object.
    3. The attempt at a solution
    [tex]\rho[/tex]_steel*V_steel*g+[tex]\rho[/tex]_gas*V*g=[tex]\rho[/tex]_water*V*g
    Solve for V_steel: *gravity cancels*
    V_steel= ([tex]\rho[/tex]_water*V)-([tex]\rho[/tex]_gas*V)/([tex]\rho[/tex]_steel)
    plug in values:
    density water = 1000 kg/m^3
    density gas = 680 kg/m^3
    density steel = 7800 kg/m^3
    Volume of drum= 260 L = .26 m^3
    Answer: 1.1 * 10^-2 (which was not the correct answer)
  3. Dec 5, 2009 #2
    Borek
    Staff: Mentor
    Steel displaces water as well.
  4. Dec 5, 2009 #3
    One assumption that you make which may be throwing you off is that the volume of steel is negligible. In other words there are two volumes, one of gas and one of steel which displace a total volume of water. See if that helps. Otherwise me answer of 10.66L agrees with yours.
    EDIT: Simultaneous post there.
Similar Discussions: Buoyancy and Archimedes' Principle
Loading...
