I Buoyancy calculations
  1. Jul 27, 2017 #1
    As a note, this is my first post on this site. I was looking at some bouyancy calculations with regard to balloons being in air when I came across this post. I cannot understand why the calculation for the net force of bouyancy done by Vintage (the last post on the page) does not include the volume number in the calculation. Does it have something to do with it being calculated at STP? Should the calculation not inlcude a number for the volume of the balloon? Is there some condition that the volume term can be ignored?
    https://physics.stackexchange.com/questions/9204/buoyancy-helium-vs-hydrogen-balloons
  3. Jul 28, 2017 #2
    Orodruin
    Staff Emeritus
    2017 Award
    The numbers presented are buoyancy per volume. Look at the units.
  4. Jul 28, 2017 #3
    How did they get to buoyancy per volume from that formula, though? There is no point when you divide by the volume. I am confused.
  5. Jul 28, 2017 #4
    Orodruin
    Staff Emeritus
    2017 Award
    You divide by the volume and so the volume cancels.
  6. Jul 28, 2017 #5
    He's making a mathematical statement about how much buoyant force would be gained for each m^3 of volume.
  7. Jul 29, 2017 #6
    Ok. I see. Thanks!
  8. Jul 29, 2017 #7
    Nidum
    One of the favourite discussion problems of our VI form physics teacher was what happens when a hydrogen balloon is only partly inflated at ground level . Assuming it is inflated enough to rise what happens to the balloon as reaches higher altitudes ?
  9. Jul 29, 2017 #8
    Orodruin
    Staff Emeritus
    2017 Award
    The same thing that happens to a scuba diver's lungs if he holds his breath while ascending. There is a reason emergency ascent when scuba diving includes shouting "aaaaaaaaaahhhhhhhh".
  10. Jul 30, 2017 #9
    Nidum
    Anyone else ?
  11. Jul 30, 2017 #10
    I concur. If it's inflated with hydrogen enough to gain positive buoyancy then it will expand as it rises to higher altitudes and eventually burst like any hydrogen balloon.
    Or does the density of the atmosphere decrease faster than the pressure with respect to altitude? If that's the case then a small enough amount of hydrogen might reach neutral buoyancy before the exterior pressure decreases enough to allow it to expand.
    Ok it's a conditional answer but that's my answer.
  12. Jul 30, 2017 #11
    Well it is actually shown in this video what happens. It grows and eventually pops. As the pressure gets lower at higher altitudes the gas expands. Density and pressure are in this case directly related via ##p =p_0 -ρgz## where ##p_0## is the pressure at ground level, ##ρ## the density, ##g## the gravitational acceleration and ##z## the height above the ground.
    [EDIT]
    It is actually common practice to only partially fill weather balloons with hydrogen as it would otherwise pop too early.
  13. Jul 30, 2017 #12
    After my last post I looked into my own question and found that indeed, the balloon would expand and burst.
    [QUOTE="
    [EDIT]
    It is actually common practice to only partially fill weather balloons with hydrogen as it would otherwise pop too early.[/QUOTE]
    That's one of the main issues with all modern airships as well. Upon gaining altitude you have to vent helium, or at least collect it back into storage, which can be a pain.
  14. Jul 30, 2017 #13
    Nidum
    Getting there .
    Assuming that the balloon does not burst during ascent what effect does full or partial inflation have on the maximum altitude that can be reached by the balloon ?
  15. Jul 30, 2017 #14
    A balloon fully inflated at ground level would burst sooner than a partially inflated balloon, clearly, assuming the two are identical apart from the amount of gas inside them. But if we assume that neither bursts at any point during their ascent then we have to conclude they would reach the same altitude, where air density is low enough to stop providing any positive buoyancy. But in that case the balloons are clearly not identical, since one of them is withstanding a far greater pressure difference than the other without bursting.
    Am I missing something?
  16. Jul 31, 2017 #15
    Nidum
    Assume that the balloon fabric is inelastic so that maximum inflation volume is fixed .
    The initially fully inflated balloon is at maximum volume at launch . The initially partially inflated balloon will swell as it climbs until it too reaches maximum volume .
    Once at maximum volume the buoyancy force acting on each balloon is the same at any given altitude and is reducing at the same rate as the balloons ascend further .
    There is something different about the two balloons though which will affect the maximum altitudes reached by each - what do you think that difference is ?
  17. Jul 31, 2017 #16
    This equation is incorrect. The correct equation is $$\frac{dp}{dz}=-\rho g=-\frac{pM}{RT(z)}g$$where T is the temperature at altitude z. and M is the molecular weight of air. The relationship of the density follows from the ideal gas law. So $$p=p_0e^{-\int_0^z{\frac{Mg}{RT(z')}dz'}}$$
Have something to add?
Draft saved Draft deleted
