Understanding Buoyancy: Answering the Question on Stone Immersion
In summary, the conversation discusses the concept of buoyancy and how it relates to the weight of an object and the weight of water it displaces. The speaker mentions conducting an experiment with a stone and a spring balance to demonstrate buoyancy, and how the buoyant force remains constant as the object is fully immersed in water. The conversation also touches on the factors that determine the amount of buoyancy on an object and when the buoyant force is at its maximum. The conversation ends with a challenge to write an equation for the relationship between buoyancy and the fraction of an object submerged in water.
physics kiddy
135
Hello everyone,
Suppose, we have a stone tied to one end of a rubber string. We suspend the stone by holding the balance or the string.Then, note the reading on the spring balance. Now, slowly dip the stone in water in a container. Our teacher told that the stone faces buoyancy as soon as it is dipped. When the stone is fully immersed in water, no further decrease in elongation is observed in the string. Please explain why does that happen.
Likes zay47olali
What have you tried? What determines the amount of buoyancy on an object?
Obviously, weight of an object = weight of water displaced by it = buoyant force.
Good. So how does the buoyant force change as the object is
000% submerged
001% submerged
037% submerged
084% submerged
099% submerged
100% submerged 1 mm under the surface
100% submerged 10 km under the surface
in particular when is the buoyant force maximal?
That's the problem. I don't know when it is maximum and minimum.
So you said "Obviously, ***weight of an object ***= weight of water displaced by it = buoyant force." Which was mostly right, as in general we do not have weight of an object = weight of water displaced by it. So we start lowering the object into water. For simplicity assume that we only lower it, and do not for example alternate raising with lowering. At each instant the buoyancy depends only upon the fraction of the object submerged. Try to write an equation for this. In particular that buoyancy does not change when the fraction submerged does not, including when the object is raised or lowed without changing the fraction submerged.
1. What is buoyancy?
Buoyancy is the upward force that a fluid exerts on an object that is partially or fully submerged in it. It is caused by the difference in pressure between the top and bottom of the object, and it is directly proportional to the volume of fluid that the object displaces.
2. How does buoyancy work?
Buoyancy works by comparing the weight of the fluid that an object displaces to the weight of the object itself. If the weight of the fluid is greater than the weight of the object, the object will float. If the weight of the fluid is less than the weight of the object, the object will sink.
3. How is buoyancy related to density?
Buoyancy is related to density through Archimedes' principle, which states that the buoyant force on an object is equal to the weight of the fluid that the object displaces. Since density is a measure of an object's mass per unit volume, it plays a role in determining how much fluid an object will displace and therefore the buoyant force acting on it.
4. What factors affect buoyancy?
The main factors that affect buoyancy are the density of the fluid, the volume of the object, and the acceleration due to gravity. The shape and size of the object can also play a role, as well as any external forces acting on the object (e.g. wind or waves).
5. How is buoyancy used in everyday life?
Buoyancy has many practical applications, such as in shipbuilding, where the shape and size of the hull are designed to displace enough water to keep the ship afloat. It is also used in scuba diving equipment, hot air balloons, and even in the human body to help us float in water. Additionally, understanding buoyancy is important in understanding weather patterns, ocean currents, and other natural phenomena.
20K
  • Classical Physics
