Buoyancy Problem
  • Thread starter jdg
jdg
23
A chunk of carbon steel with density, ρ = 7.84 g/cm3 , is completely submerged in fresh water. The chuck of steel weighs 30 N more in air than in water
Fb= ρgV ?
How do you find the buoyancy without being given the volume? Should I assume 1 cm^3?
Answers and Replies
jgens
50
It would help if we knew the question! Assuming that the question is "what is the buoyant force acting on the chunk of carbon steel?" use the fact that the block weighs 30 N less in water than in air. Try writing out the equations for the block's weight in each case.
jdg
23
I got that far, I'm not sure how to set up a problem like that. I found the specific gravity of steel in fresh water (d_steel/d_water)= (7840/1000)= 7.84
jdg
23
The questions were:
1. Find the buoyant force acting on the chunk of steel
2. Find the the volume of the chunk of steel
jgens
50
Well, the weight of the carbon steel chunck in air should be: Wair = mg
The weight of the carbon steel chunk in water should be: Wwater = mg - ???
And: Wair - Wwater = ???
Edit: Thanks for the questions! If you can solve this first one, you can solve the second question really simply!
jdg
23
Yea, my problem is, how do I find the mass? If I assume 1 m3 for the volume, it is 7840 kg
jgens
50
Um, you're not looking at this problem the right way. If Wair is greater than Wwater by 30 N, what does that suggest about Wair - Wwater?
Hint: To do this problem, you don't need to make any assumptions! :)
jdg
23
Wair - Wwater
Ok, so Wair - (Wair-30N)?
jgens
50
Yes! So this means that: Wair - (Wair - 30 N) = ???
jdg
23
mg-30?
jdg
23
wait, so the Wair's cancel and you get -30N?
jgens
50
No! Write out the expression for the weight of the carbon steel chunk in water and subtract it from the expression for the weight of the chunk in air.
Hint: Your expression should include the buoyant force.
Edit: Yes, the Wair cancels out, but: -(-30 N) != -30 N
jdg
23
ok awesome, so Fb= Fair-(Fair-30N)= 30 N? Then, volume= Fb/d*g (d=density) = 30/(7840*9.81) = 3.901e-4?
jgens
50
Yes! Fb = 30 N.
That's what I get for the Volume as well, or equivalently V = 390 cm3.
jdg
23
ok, so for weight in air it would be 30 N + 30 N= 60 N? And the mass would be m = Fair/g or m = (Fair-Fb)/g?
jgens
50
For the mass, use the relationship: ρ = m/V
Edit: Oops! Used the wrong density in calculating the volume, remember that the buoyant force equals the weight of the water displaced! I'm terribly sorry about that.
jdg
23
thanks a lot! you have time for one or 2 more?
jgens
50
Yeah, I can help on a couple more problems, but you may want to re-do a couple of the calculations. Sorry!
I don't think you can find the weight in air. It's juts "30N" heavier than in the weight water.
Following from jgens, the volume should be about 3.058e-3
jdg
23
Ok, I got: Fair= mg = 30 N
m = dV = (7840)(3.901e-4) =3.06 kg
V = Fb/dg = (30 N) / (7840*9.81) = 3.901 m3
Next question: A garden hose with internal diameter of 13.5 mm lies flat on a sidewalk while water is flowing in it at a speed of 6 m/s. A person happens to step on it at the very edge of the opening of the hose and decreases its internal diameter by a factor of 9
So D (1) = 0.0135m
r (1) = 0.00675m
D (2) = 0.0135/9 = 0.0015m
r (2) = 0.00075m
A (1) = pi*r^2 = (3.14...)(0.00675^2) = 1.4134...e-4
A (2) = pi*r^2 = (3.14...)(0.00075^2) = 1.767...e-6
1. What was the water flow rate in the hose prior to the person stepping on it?
- I got this part: J(1) = A(1)V(1) = 8.59 m3/s
2. What is the flow rate of water after the person steps on it?
3. What is the speed of the water just as it exits the hose after the person steps on it?
jgens
50
Not sure I agree with this. Start with Fb = 30 N. Now, use the eqaution Fb = ρwaterVg to find the volume. Then use the relationship ρ = m/V to find the mass.
jdg
23
ok, I got V = 0.003058...
m = 23.975...
jdg
23
for Q2, part 2 I did J = A(1)V(1) = A(2)V(2):
So V2 = V1*(A1/A2) = 486 m/s
Is this right?
And for part 3 I did
J = (A2)(V2) = 8.59e-4 m3/s
Related Threads on Buoyancy Problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
