• Support PF! Buy your school textbooks, materials and every day products Here!
Buoyant Force & Acceleration
  • Thread starter AG1189
1. Homework Statement
-A thin spherical shell of mass 0.300 kg and diameter 0.250 m is filled with alcohol ( = 806 kg/m3). It is then released from rest on the bottom of a pool of water. Find the acceleration of the alcohol filled shell as it rises toward the surface of the water.
2. Homework Equations
FB-(M1+M2)g=(M1+M2)a
3. The Attempt at a Solution
M1=0.3kg, r=0.125 m, V= (4*pi*r^3) /3,
M2 = pV = (806*V), FB = pVg = (1000)(V)(9.8)
. After finding FB, I plugged it back into the equation and got 2.211 m/s^2. This answer was wrong, could someone please tell me if I am using the wrong equation, or if I just screwed something up.
175
It looks like you might have just done something wrong in your calculations...I set it up like this:
[tex]
\sum{F} = \rho_{water} V g - \rho_{alcohol} V g - mg = (m + \rho_{alcohol} V) a
[/tex]
[tex]
a = \frac{g(\frac{4}{3} \pi r^3 (\rho_{water} - \rho_{alcohol}) - m)}{m + \rho_{alcohol} \frac{4}{3} \pi r^3}
[/tex]
and I got a number a little lower than yours. Maybe it was rounding? Generally I like to get everything in one equation and then plug it all in at once to reduce the chance of that sort of mistake.
it worked out, thank you very much. I got 1.829711 m/s^2, I think thats what you got. :smile: :smile:
Related Threads for: Buoyant Force & Acceleration
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
