audiguy
- 1
Hi,
I'm a new member looking for a little help.
I'm working on an automotive suspension project where we replace "electronic damping control" struts with a coilover that has no sensor. I'm looking to bypass the sensor and trick the ECU to thinking they are still hooked up. The resistance of each damper is 2.3 ohms and runs on a 12 volt system, with a 2 wire connection to each. Could I run a 3ohm resistor on each wire into a diode to trick the ECU? Any thoughts?
