Is the Sup Metric Used to Minimize Writing d_infinity in C[0,1]?
  • Thread starter coverband
  • Tags
    Metric
In summary, the conversation is discussing the use of the sup metric and its notation in the context of C[0,1]. The sup metric, conventionally denoted as d_\infty, is used to calculate the maximum distance between two functions f and g in C[0,1]. By stating "consider C[0,1] with the sup metric," this means that every time the symbol d is used, it refers to the sup metric. This saves time and effort in writing d_\infty repeatedly.
coverband
171
in a question if you're asked to CONSIDER C[0,1] with the sup metric, does this mean that for the appearance of d(g,f) throughout this question the MAXIMUM distance between g and f (i.e. d_infinity) is to be considered?
Its like a way of saving writing d_infinity all the time if you just state at the start "consider with the sup metric" and have d alone throughout ?
They denote the metric (conventionally) by d and they mean that d is the sup metric (which, if more than one metric is relevant, is conventionally denoted [itex]d_\infty[/itex]). So
[tex]d(f, g) = \sup_{x \in [0, 1]} |f(x) - g(x)|[/tex]
(assuming the metric on [0, 1] is just the Euclidean one :smile:)
If that's what you meant, you're right.
So "consider C[0,1] with the sup metric..." means everytime you see "d" throughout the question, this means "d_infinity"
This means that whenever one refers to the metric of [itex]C[0,1][/itex], be it by the symbol [itex]d[/itex] (provided this symbol is used in this context to denote the metric of [itex]C[0,1][/itex]) or otherwise, one means the sup metric, which is usually denoted [itex]d_\infty[/itex].
cool thank s
1. What is C[0,1] with the sup metric?
C[0,1] with the sup metric refers to the set of all continuous functions on the closed interval [0,1] with the sup norm or metric. This metric measures the maximum distance between two points on the function, giving a measure of how far apart the function values can be.
2. How is the sup metric defined?
The sup metric, also known as the supremum metric, is defined as the maximum or supremum of the absolute difference between two points on a function. Mathematically, it is expressed as: d(f,g) = sup|f(x) - g(x)| for all x in [0,1].
3. What is the significance of using the sup metric in C[0,1]?
The sup metric is useful in C[0,1] because it gives us a way to measure the distance between two continuous functions on the interval [0,1]. This can be helpful in various applications, such as optimization problems or studying the convergence of sequences of functions.
4. How is the sup metric different from other metrics?
The sup metric differs from other metrics, such as the Euclidean or Manhattan metrics, in that it does not take into account the actual shape or path of the function. Instead, it focuses on the maximum difference between two points on the function.
5. Can the sup metric be extended to other intervals besides [0,1]?
Yes, the sup metric can be extended to any closed interval [a,b] where a and b are real numbers. It can also be extended to other sets, such as the set of all polynomials or the set of all bounded continuous functions on a given interval.
  • Linear and Abstract Algebra
  • Topology and Analysis
