C# Adding Program
  1. Oct 27, 2013 #1
    TheDemx27
    Just starting to learn C#. I just wrote this program to add two numbers and loops by looking up syntax etc. There HAS to be a more efficient way to do this.
    Code (Text):
    using System;
        public class Program
            static void Main()
                bool repeat = true;
                while (repeat == true)
                        string x;
                        string y;
                        int xint;
                        int yint;
                        string useranswer;
                        Console.WriteLine("Enter 'X':");
                        x = Console.ReadLine();
                        xint = int.Parse(x);
                        Console.Clear();
                        Console.WriteLine("Enter 'Y':");
                        y = Console.ReadLine();
                        yint = int.Parse(y);
                        Console.Clear();
                        int answer = xint + yint;
                        Console.WriteLine("{0} + {1} = {2}", x, y, answer);
                        Console.ReadLine();
                        Console.WriteLine("Run again?: Y/N");
                        useranswer = Console.ReadLine();
                        Console.Clear();
                        if (useranswer == "y" || useranswer == "Y")
                            repeat = true;
                        else
                            repeat = false;
  3. Oct 27, 2013 #2
    jim mcnamara
    Staff: Mentor
    You could pass X and Y from the command line.
  4. Oct 28, 2013 #3
    AlephZero
    That's about as good as it gets, for reading input. C# doesn't have "easy to use" functions like scanf() in C or the << operator in C++. But those easy to use functions are not much use except for toy programs, because it's very hard to catch errors in the input.
    You could make the code a neater by "factoring out" the repeated code and writing your own input function, something like
    Code (Text):
    int getvalue(string prompt)
      Console.WriteLine(prompt);
      string x = Console.ReadLine();
      Console.Clear();
      return int.Parse(x);
    xint = getvalue("Enter X:");
    yint = getvalue("Enter Y:");
    (Note, I haven't actually tested that code!)
    Your test for repeating the loop is a bit longwinded. You could write
    Code (Text):
    repeat = (useranswer == "y" || useranswer == "Y");
    or even
    Code (Text):
    repeat = (useranswer.ToLower() == "y");
    You can also make your code shorter by declaring variables when you first use them, instead of by separate statements at the top of a function, as I did in
    Code (Text):
    or even
    Code (Text):
    var x = Console.ReadLine();
    where "var" means "the compiler can figure out what type of variable this is, so I don't really care".
  5. Oct 29, 2013 #4
    you could just use a forms app instead of a console app which is much more efficient or
    Console.WriteLine("{0} + {1} = {2}", x, y, xint+yint);
    maybe that will work its been awhile since ive done a console app. get visual studio it's so superior.
  6. Oct 30, 2013 #5
    harborsparrow
    It's advisable to error check all inputs. You can do it like this. Once you get an input, check to see if it really is an integer:
    try
    Int.Parse(myinputstring);
    catch (Exception ex)
    Console.WriteLine("That was not an integer.");
    And yes, it will probably be needful to use a goto statement, or else, use a flag to create a rather obscure loop, until you get all legal inputs.
  7. Oct 30, 2013 #6
    harborsparrow
    And never, ever use Int.Parse without enclosing it in a try/catch, because otherwise your program can throw an obscure error message to the user upon bad input. When I was teaching, that would earn you an instant failing grade.
