Homework Help: C++ function problem
  1. Oct 6, 2008 #1
    In our C++ class, we're learning to use functions. In this problem I am working on is to use 4 functions: 3 functions to get your first name, last name, middle initial, and one function to display the your full name.
    I wrote the program, but can't get it to run. I've looked over it several times and I don't see where I went wrong. Can anyone see where the error is?
    Oh, I wrote it using Visual C++ 2008 Express Ed.
    #include <iostream>
    #include <string>
    using namespace std;
    string GetFirstName();
    string GetLastName();
    char GetMiddleInitial();
    void DisplayFullName(string firstName, string lastName, char middleInitial);
    int main()
    string firstName;
    string lastName;
    char middleInitial;
    firstName = GetFirstName();
    lastName = GetLastName();
    middleInitial = GetMiddleInitial();
    DisplayFullName(firstName, lastName, middleInitial);
    system("pause");
    return 0;
    string firstName;
    cout << "Enter your first name: ";
    cin >> firstName;
    return firstName;
    string lastName;
    cout << "Enter your last name: ";
    cin >> lastName;
    return lastName;
    char middleInitial;
    cout << "Enter your middle Initial: ";
    cin >> middleInitial;
    return middleInitial;
    cout << "Your full name is " << firstName << " "
    << middleInitial << ". "
    << lastName << ".";
  3. Oct 6, 2008 #2
    mgb_phys
    Posting the problem / error message might help.
    I suspect you want to look at std::getline since you are on windows
  4. Oct 6, 2008 #3
    Here's the what the output window says when I run it...
    1>Linking...
    1>MSVCRTD.lib(crtexe.obj) : error LNK2019: unresolved external symbol _main referenced in function ___tmainCRTStartup
    1>C:\Documents and Settings\HP_Administrator\My Documents\Visual Studio 2008\Projects\a\Debug\a.exe : fatal error LNK1120: 1 unresolved externals
    1>Build log was saved at "file://c:\Documents and Settings\HP_Administrator\My Documents\Visual Studio 2008\Projects\a\a\Debug\BuildLog.htm"
    1>a - 2 error(s), 0 warning(s)
    ========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
  5. Oct 6, 2008 #4
    Maybe you told Visual Studio to use the precompiled header, but then removed the references to it.
    With Visual Studio, you need to uncheck "use precomiled header" when you make a project, or ensure that you keep all the information that Visual Studio includes for you in the blank project.
    When I copy and pasted it, it ran fine. If you are using the precompiled header, ensure that you use #include "stdafx.h" and you should probably use int _tmain(int argc, _TCHAR* argv[]) for the main function.
    If you uncheck "include precompiled header" when you first make the project, you do not have to include the stdafx.h library.
  6. Oct 6, 2008 #5
    Yes...that's exactly what it was. When I made a new project for this I must have forgotten to check the 'Empty Project' box. I wouldn't have thought to check that, thank you.
    I kept going over the code many times, it was driving me all kinds of crazy.
