[C++] g++ compiler question
  1. Aug 10, 2012 #1
    So here is the class constructor that is giving me issues:
    Code (Text):
    cPlayer::cPlayer (SDL_Surface *tank, SDL_Surface *bullet, SDL_Surface *screen)
    Several definitions of variables declared in the class header file
    When I compile it, it g++ says "warning: extended initializer lists only available with
    -std=c++0x or -std=gnu++0x [enabled by default]" 4 times.
    I'm curious as to what is causing this warning to appear because I am clueless as to what it means.
    Thanks for reading, and any help is much appreciated.
    -Peter P.
    EDIT: I found the problem. I was defining things a certain way that was causing the warning to pop up.
Draft saved Draft deleted
