Homework Help: C: Highly prime numbers
  1. Feb 29, 2016 #1
    Write a program that will print all highly prime numbers from the input interval <a,b>. Prime number is highly prime if deletion of every digit from right is a prime.
    Example:
    239 is highly prime because 239,23,2 are primes.
    2. The attempt at a solution
    Could someone point out what are logic errors in the following program:
    Code (Text):
    #include <stdio.h>
    int isPrime(int p);
    int isHighlyPrime(int n);
    void printHighlyPrimeNumbers(int a,int b);
    // check if p is a prime
    int isPrime(int p)
      int nd=2;//number of divisors
      int d;//current divisor
      for(d=2; d<p/2; d++)
      if(p % d == 0)
      nd++;
      if(nd == 2)
      return 1;
      return 0;
    // check if n is highly prime
      int temp=n;
      int i;
      int digitCount=0;//number of digits in n
      while(temp != 0)
      temp=temp/10;
      digitCount++;
      temp=n;
      //if number of digits is 1, only check if prime
      if(digitCount == 1)
      if(isPrime(temp))
      return 1;
      //else check if n,n/10,(n/10)/10,... are primes
      else
      for(i=1; i<=digitCount-1 && isPrime(temp); i++)
      if(isPrime(temp))
      temp=temp/10;
      return 1;
      return 0;
    //print highly primes from a to b
      int i;
      for(i=a; i<=b; i++)
      if(isHighlyPrime(i))
      printf("%d ",i);
    int main()
      int a,b;
      do
      printf("a = ");
      scanf("%d",&a);
      }while(a<1);
      do
      printf("b = ");
      scanf("%d",&b);
      }while(b<1);
      //swap if a>b
      if(a > b)
      int temp=a;
      a=b;
      b=temp;
      printHighlyPrimeNumbers(a,b);
      return 0;
  3. Feb 29, 2016 #2
    Samy_A
    This part I don't get:
    Code (C):
      if(isPrime(temp))
      temp=temp/10;
    I would keep the for loop simple:
    Code (C):
    for(i=1; i<=digitCount-1; i++)
    Then, if isPrime(temp) returns 0, isHighlyPrime should immediately return 0.
    (Also, note that your isPrime function considers 4 a prime number.)
  4. Feb 29, 2016 #3
    BvU
    2017 Award
    Seems flawed: if it's prime you don't have to IF again. If it's not prime, you should not return 1 .
    [edit] quick work Samy !
  5. Feb 29, 2016 #4
    [EDIT]I have figured out the problem, here is the working program:
    Code (Text):
    #include <stdio.h>
    int isPrime(int p);
    int isPrime(int p)
      int i = 2;
     if(p == 1 || p == 7)
        return 0;
      while(i<p){
      if(!(p % i)) return 0;
      i = 2*i-1;
      return 1;
      int temp=n;
      int i;
      while(temp != 0)
      temp=temp/10;
      digitCount++;
      temp=n;
      if(digitCount == 1)
      if(isPrime(temp))
      return 1;
      else
      while(temp>0)
      if(isPrime(temp) == 0)
      return 0;
      temp =temp/10;
      return 1;
      return 0;
      int i;
      for(i=a; i<=b; i++)
      printf("%d ",i);
    int main()
      int a,b;
      do
      printf("a = ");
      scanf("%d",&a);
      }while(a<1);
      do
      printf("b = ");
      scanf("%d",&b);
      }while(b<1);
      //swap if a>b
      if(a > b)
      int temp=a;
      a=b;
      b=temp;
      return 0;
  6. Feb 29, 2016 #5
    Samy_A
    Some examples: the program treats numbers as 113, 131, 137 ... as highly prime.
    Also 77, 371, 377 and 1133, which are not prime.
    Something still wrong with the isPrime function.
  7. Feb 29, 2016 #6
    I have edit the previous post, but not sure if it will correct possible error.
  8. Feb 29, 2016 #7
    Samy_A
    Still gives 371 and 373 as primes (as examples).
    As 7 is prime, returning 0 when p==7 doesn't make much sense.
    The key issue is this: in isPrime, you check if p is divisible by i=2, and then by i=2*2-1=3, i=2*3-1=5, i=2*5-1=9, ...
    See the problem?
  9. Feb 29, 2016 #8
    The following isPrime() function seems to work for interval 50 - 1200:
    Code (Text):
    int isPrime(int p)
      int i;
      if(p == 1)
      return 0;
      for(i=2; i<=p/2; i++)
      if(p % i == 0)
      return 0;
      return 1;
  10. Feb 29, 2016 #9
    Samy_A
    Yes, this one looks ok (I'm tired, so I may miss something). There is room for improvement as far as performance is concerned, but probably that is not important at this stage.
Have something to add?
Draft saved Draft deleted
Loading...
