C++ is crazy difficult.
  1. Oct 25, 2012 #1
    I'm into my second year now at uni and after learning Java for the past year, the course is now introducing us to C++. We're still doing java but now C++ aswell.
    I don't know if I'm the only one but C++ is sooooo much harder than java, today after just our second lesson we're being introduced to header files and coding our own. it took my 2 hours just to figure out how to right a program that read from a file, command line arguments and then added up the number of arguments and printed out the sum of those arguments.
    The thing is our lecturer uploads the solutions to the problems 1 week after the problem was given to us, so I can always wait until the solution is provided and then try to peice together what is going on, but I just don't understand it.
    Everything seems to be moving at such a fast past and I'm just slipping behind, I'm 1 week behind so far and tomorrow is the next exercise and I still can't complete last weeks one :/
  3. Oct 25, 2012 #2
    phinds
    Is there a question in here somewhere or did you just need to get that off your chest? :smile:
  4. Oct 25, 2012 #3
    Mainly just to get it off my chest lol. Also for someone to tell me that they were in my position and it's just a hurdle that you need to overcome and once you start doing more C++ you'll get used it it?
    I dunno really =(
  5. Oct 25, 2012 #4
    rcgldr
    Seems the main issue here is pointers, and in this case, a pointer to an array of pointers to the arguments, often declared as a pointer to a pointer to a character ( ... , char **argv ) or sometimes as an array of pointers to characters ( ... , char *argv[] ). The end result is basically the same, since C / C++ treats arrays and pointers similarly.
  6. Oct 25, 2012 #5
    Pointers can be non-intuitive to the Java programmer.
    But headers already after week 2? That's a little too accelerated.
  7. Oct 25, 2012 #6
    This has always mystified me since Java has pointers too: Java references are, in fact, just pointers.
    In my experience there are a couple of things in particular that seem to blow Java programmers minds when they come to programming in C++:
    • the lack of a garbage collector and the resultant necessity to engage in manual memory management for anything allocated on the heap;
    • the ability to store actual objects - not just pointers or references to objects - as members in other objects.
    The first isn't actually a problem since the advent of smart pointers and RAII mean that nobody beyond library writers should really need to worry about memory management. The second is fixed simply with practice.
  8. Oct 25, 2012 #7
    AlephZero
    You can't write any C++ (or even C) programs without using the predefined headers, and you can't write any non-trivial code that is sensibly stuctured without writing your own headers.
    If you already know Java, this probably isn't a first programming course that spends two weeks explaining what "i = i + 1" means. I would have thought you would be meeting headers within in the first two hours, not the first two weeks.
  9. Oct 25, 2012 #8
    Hurkyl
    Staff Emeritus
    Of course, that doesn't stop some people from teaching/learning C++ from a 25-year old perspective on using the language.
    Because of this, "I'm learning C++" can mean a very wide variety of things. :frown:
  10. Oct 25, 2012 #9
    rcgldr
    I think the syntax is part of the issue, since it doesn't consistently flow left to right:
    char achar[]; // array of characters
    char * pchar; // pointer to character
    char ** ppchar; // pointer to pointer to character
    char * papchar[]; // pointer to array of pointers to characters
    Then there's the issue that pointers can be used similar to arrays:
    ... *(pchar + 1) is the same as ... pchar[1]
    The syntax for pointer to function isn't obvious either:
    int (*pfun)(void); // ptr to function wtih no parameters and returning integer
  11. Oct 25, 2012 #10
    pwsnafu
    Ah, the old days of programming when people said "I program in C++ because Java is too slow". I was just talking to a programmer who was saying "I program in Java because Ruby is too slow" :rofl:
  12. Oct 25, 2012 #11
    Yesterday I got lost in my own C++ code. I totally forgot WTF I was doing. So I hear ya... My two semesters of Java was a walk in the park compared to my first semester of C++!
    But that means you're learning, too. :p
  13. Oct 25, 2012 #12
    jhae2.718
    Things like
    Code (Text):
    [color=#B00040]char[/color] [color=#666666]*[/color]([color=#666666]*[/color]c[[color=#666666]10[/color]])([color=#B00040]int[/color] [color=#666666]**[/color]p);
    get interesting...
  14. Oct 25, 2012 #13
    D H
    Staff Emeritus
    That's because it doesn't flow left to right. For the most part, it flows right to left. In general it swings from center to right to left to right to left to ... You just have to get into the swing of things.
    Code (Text):
    char const * foo;
    // foo is a pointer to a const char.
    // Simply read from right to left.
    char * const bar;
    // bar is a const pointer to a char.
    // Once again, just read right to left.
    int *(*baz(double red_herring))[];
    // baz is a pointer to a function that takes a double and
    // returns a pointer to an array of pointers to integers.
    // Now we really do need to get into the swing of things.
    // How to read this:
    //   1. Find the identifier: It's baz. That "red_herring" is a red herring.
    //      baz is ...
    //   2. Read to the right: ... a function that takes a double.
    //   3. Stop at the unbalanced close paren and read to the left:
    //       ... a pointer to a function that takes a double ...
    //   4. Stop at the open paren, swing back to reading to the right:
    //      ... that returns an array ...
    //   5. Stop at the semicolon, swing back to reading to the left:
    //       ... of pointers to integers.
    // Easy-peasy! :)
  15. Oct 25, 2012 #14
    D H
    Staff Emeritus
    c is an array of 10 function pointers each of which takes a pointer to a pointer to an int as an argument and returns a pointer to a char.
  16. Oct 25, 2012 #15
    rcgldr
    Except this is also allowed:
    Code (Text):
    const char * foo;
    There's also two ways of accessing members via pointers to structures or classes:
    (*pobject).member or pobject->member
    Then C++ added another alternative with function parameters accessed by reference
    using pointer:
    Code (Text):
        fun(&object);
    void fun (OBJECT * pobject)
    ...  pobject->member  ...
    using reference.
    Code (Text):
        fun(object);
    void fun (OBJECT &object) // parameter is actually pointer to object
                              // allowing object to be modified by fun
    ...  object.member  ...
    With reference method, you can't tell from the call if the function can modify object (pass by reference instead of pass by value), you have to look at the function or it's prototype, which could be located in a separate header file.
    The classic mistake if(x = 1)... when you meant if(x == 1) ...
    One of the cases where whitespace matters:
    a+*ptr2b (a plus (*ptr2b))
    a-*ptr2b (a minus (*ptr2b))
    a**ptr2b (a times (*ptr2b))
    a/*ptr2b (/* comments out all remaining code until */ if there is any)
  17. Oct 25, 2012 #16
    Here's a strange pointer-related "feature" of C++. Suppose we define a five-element array of ints, a, to store the integers from 0 to 4. Everyone knows that the following prints '4' to stdout:
    Code (Text):
    std::cout << a[4] << std::endl;
    If you want to mess with someone's head, the same result can be achieved using the following code:
    Code (Text):
    std::cout << 4[a] << std::endl;
    You're well on your way to understanding pointers and arrays if you can wrap your head around why this works.
  18. Oct 25, 2012 #17
    D H
    Staff Emeritus
    That's a misfeature, not a feature, and it's an inherited misfeature from C. It's due to the extremely weak support in C for arrays. Unfortunately, this is one of the misfeatures that makes C a bit poor for scientific computing.
    All in my opinion, of course.
  19. Oct 25, 2012 #18
    Mark44
    Staff: Mentor
    Simple - here's the definition of that array.
    Code (Text):
     int 4[a] = {0, 1, 2, 3, 4};
    :wink:
  20. Oct 25, 2012 #19
    D H
    Staff Emeritus
    No. It's worse than that, Mark. 4[a] and a[4] as an lvalue or rvalue refer to exactly the same thing. It's because C treats the operator [] as syntactic sugar for pointer addition and deferencing. a[4] is just a sugar coated version of *(a+4), and 4[a] is just a sugar coated version of *(4+a).
  21. Oct 25, 2012 #20
    jhae2.718
    If you have a copy of Expert C Programming: Deep C Secrets, the commutativity of the subscript operator is discussed some on p. 243.
  22. Oct 26, 2012 #21
    rcgldr
    My favorite post in this thread.
    Getting back to the OP, once you get past the terse syntax of C / C++ and perhaps the STL (standard template library) that your class may get into later on, you'll find the actual programming to be similar to what you would do with any programming language.
  23. Oct 26, 2012 #22
    Ben Niehoff
    C is a logical, if complex, language. Everyone complains about pointers, but once you get the concept, really it is just a simple idea that can be chained together into more complex things.
    C++, on the other hand, is an unholy beast. It's a mashed-together conglomeration of both procedural and object-oriented ideas, and there are way too many fiddly details about the implementation of the language that must be memorized in order to write in it effectively. Seriously, what is the need for both references and pointers?
    If speed is critical in your application, use plain C. If you like doing things object-oriented, use Java or some other high-level language.
  24. Oct 26, 2012 #23
    Such as?
    There are several reasons why references are a good idea. Here's two off the top of my head:
    • For safety reasons, when using pointers you need to be obsessive about checking for nulls; references are guaranteed to always be non-null.
    • References give you a straightforward way of implementing operator overloading.
  25. Oct 26, 2012 #24
    I'd say that C++ is, well, a cover-all language, which tries to allow for a lot of paradigms and sub-paradigms. I will agree, it can get unnecessarily mashed-up at times, and the lack of memory management can be a little annoying.
    All languages equal in their own right, C++ is my personal favourite, so I'll try to point out the good parts and gloss over the flaws, since that's what I do with stuff I like. Multiple Inheritance is confusing and rarely useful, but when it is useful, it's useful. The more common alternative, which uses interfaces, is still possible in C++. The closest to templates I've seen in another language is Objective-C's dynamic typing.
    But, yea. It can be bulky and unwieldy.
  26. Oct 26, 2012 #25
    D H
    Staff Emeritus
    I disagree. Every language has its own idioms, its peculiar way of doing things. One of the key obstacles to learning a new language is to learn how to write in the vernacular of that language as opposed to force-fitting the idioms of some other language onto the language at hand. An even bigger issue is that some languages are fundamentally very different from one another. A pure functional language is very, very different from a procedural language.
    That's not quite fair. OO is always going to be on top of some other programming paradigm, be it procedural (Java, C++, ObjectiveC), functional (Haskell, CLOS), or logical (Logtalk).
    Do C++ the modern, RAII way and you won't use very many pointers. The C++ standard library provides a number of mechanisms that in many cases eliminate the need for pointers. Needing a pointer is a bit of a code smell. Needing a void* pointer is worse than code smell. The ubiquity of void* in C versus its absence in well-written C++ is one of the key features that distinguish the two languages.
    That mish-mash just got bigger with C++11. C++03 functors started to give a bit of a functional programming flavor to the language. Lambda expressions and closures sealed the deal. The new standards makes C++ have aspects of procedural programming, object oriented programming, generic programming, meta programming, functional programming, and multiprocessing. All that's missing is logic programming.
    Smart pointers take care of a lot of those memory management problems, and do so without needing a garbage collector.
    The closest thing is Ada generics. The same two people, David Musser and Alexander Stepanov, who developed Ada generics also strongly influenced how C++ templates work and developed the bulk of the STL. Interestingly, Stepanov is fervently anti-OO: "I think that object orientedness is almost as much of a hoax as Artificial Intelligence."
    I can't argue with that.
