C language problem ?
  • Thread starter rclakmal
1Can we perform arithmetic operations between float and int variables ,
As an example can we say a+b while a is an integer and b is a float.
2 And what function below will read NUMBER of elements from a file?
fileread( )
getline( )
readfile( )
fread( )
Answers and Replies
Borek
Mentor
28,507
2,935
Yes. Look for type promotion.
fileread( )
getline( )
readfile( )
fread( )
C? stdio.h?
stdio.h header file is there !!!! i want to know what function will read number of elements from file ?/
Borek
Mentor
28,507
2,935
read can do it. Trick is, you are listing functions that as far as I remember are not present neither in io.h nor stdio.h, so I have no idea what you refer to.
sylas
Two of them are in stdio.h, and one of them is for reading a given number of elements from a FILE stream.
Borek
Mentor
28,507
2,935
Yes, two are present - but two are not.
sylas
I think it must be a simple multichoice quiz question with two dummy functions that sound plausible and don't exist, and two real functions... only one of which does what is asked.
Borek
Mentor
28,507
2,935
To some extent that's what I supposed at first, but - as such functions do exist in some languages/libraries - I wasn't sure what the question really is about; hence my attempt at clarificatin of the situation.
sylas
Use grep, egrep or fgrep to look for definitions of those four functions in stdio.h. You should be able to figure it from there.
Yr exactly .....it is the case Its a MCQ .So what will be the answer help please .
sylas
Before there was google, there was grep to answer everything... :wink:
grep stdio.h for the function definitions... or use man
You have mentioned that two functions here exist and others do not .so please tell me which one exists.
Borek
Mentor
28,507
2,935
Use grep or any other tool to check the content of stdio.h and io.h, we will not spoonfeed you.
oh thanks so much for ur VALUABLE advice !!!!!!!it was a great help!!!!!!
Related Threads on C language problem ?
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
