C program help
  • Thread starter KV305
C program help!!
Hey guys im having trouble completing this C program. Its suppose to ask the user to enter a file to read from, read the file, count how many times each word appears and print the results in a different file(also user input) arranged from high occurrence.
Heres what i have so far
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
typedef struct AWORD
char wordname[50];
int count;
}a_word;
a_word nword(char* words)
a_word new;
strcpy (new.wordname, words);
return new;
int compare (words.wordname, words[j].wordname)
if (words.count < words[j].count)
return -1;
else if (words.count > words[j].count)
return 1;
else
return 0;
int main(int argc, char *argv[])
int i = 0,j = 0,k = 0, m = 0, count = 0,count2 = 0, count3 = 0, wrdcnt = 1,$
char cur, cur2[50], file1[25], file2[25], list[1000][k], *buffer;
FILE *pFile, *pFile2;
printf("Please type the name of the input file:\n ");
scanf("%s",file1);
printf("%s",file1);
pFile = fopen(file1, "r");
printf("Please type the name of the output file:\n ");
scanf("%s",file2);
pFile2 = fopen(file2, "r");
while (cur != EOF)
cur = fgetc(pFile);
if (cur != ' ')
list[m][k] = cur;
fprintf(pFile2, "%c", list[m][k]);
k++;
if (cur != '\n' && cur != '\0')
count2++;
if (cur == '\n' || cur == '\0')
wrdcnt++;
else
if (cur == ' ')
wrdcnt++;
m++;
k = 0;
if (cur == '\0')
fprintf(pFile2,"%s", &cur);
else
fprintf(pFile2, "\n");
fclose(pFile);
fclose(pFile2);
a_word words[wrdcnt];
for (i = 0; i < wrdcnt; i++)
fgets (cur2, 50, pFile2);
words = nword(cur2);
printf("words[%d] is %s", i, words.wordname);
printf("\n");
count3 = wrdcnt;
for (j = 0; j < count3; j++)
buffer = words[j].wordname;
if (strcmp(buffer, words.wordname) == 0)
count++;
words[j].count = count;
count = 0;
printf ("\nWord Counter Program Starting...");
printf("\nWord Counter Program Finished. Check %s file\n", file2);
for (i = 0; i < j; i++)
if (strcmp(words[j].wordname, words.wordname) == 0)
same = 0;
break;
else
same = 1;
if (same == 1)
printf ("%d\t%s", words[j].count, words[j].wordname);
fprintf(pFile2, "%d %s\n", words[j].count, words[j].wordname);
fclose(pFile2);
return 0;
I havent sorted yet. we are suppose to use qsort but i dont think my compare function is right. Any help would be greatly appreciated. Thank you.
Answers and Replies
You have to create a list of words and a number for each as you have done (AWORD).
You then need to do a bubble sort - going through your list of words swapping over any pair that are the wrong way round - you do that multiple times until there are no swaps - then you know it's done.
So you need to compare a pair of integers - the number of times each word occurs in each pair.
The declaration for the compare must use a void *. (it can't cope with overloading)
You will be passing it a pair of integers so you need to cast each to a const void* in the qsort call.
Then your declaration will look like:-
int compare (const void *count1, const void *count2)
//then you cast it back to the type you want - you can do that on-the-fly
// I think you can see where it goes from here
if ((int)count1==(int)count2) return 0; //etc.
Ok so far i altered the program and gives no errors but when i try to run it it says
"Segmentation fault".... any ideas?
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
char wordname[50];
int count;
}a_word;
a_word new;
return new;
if ((int)count1<(int)count2) return -1;
if ((int)count1>(int)count2) return 1;
int i = 0,j = 0,k = 0, m = 0, count = 0,count2 = 0, count3 = 0, wrdcnt = 1,same;
char cur, cur2[50], file1[25], file2[25], list[1000][30], *buffer, sorted[1000];
scanf("%s",file1);
printf("%s",file1);
scanf("%s",file2);
while (cur != EOF)
cur = fgetc(pFile);
if (cur != ' ')
list[m][k] = cur;
k++;
count2++;
wrdcnt++;
else
if (cur == ' ')
wrdcnt++;
m++;
k = 0;
if (cur == '\0')
else
fclose(pFile);
fclose(pFile2);
printf("\n");
count3 = wrdcnt;
count++;
count = 0;
same = 0;
break;
else
same = 1;
if (same == 1)
fclose(pFile2);
m=0;
while (pFile != NULL)
fscanf (pFile2 , "%s" , &sorted[m]);
m++;
qsort(sorted,m,sizeof(int),compare);
fclose(pFile2);
pFile2 = fopen(file2, "w");
fprintf(pFile2,"%s", sorted);
return 0;
6,791
Are you in the same class as the person who started this thread?
If you're getting a segmentation fault, you are probably attempting to access memory (via a pointer) that your program is not allowed to access. It's time to learn how to use a debugger.
jtbell
Mentor
15,766
4,011
Put extra printf() statements in the program so you can pin down exactly where the segmentation fault is occurring:
"I got to checkpoint #1.
I got to checkpoint #2.
I got to checkpoint #3.
ERROR: Segmentation fault."
It means you are attempting to read or write to a part of the memory outside your own program. Usually a pointer error (accessing memory location zero because a pointer is null for example).
Try temporarily commenting out sections of your program till you locate the line giving the error - then look carefully at any pointers involved.
Doesn't your debugger automatically stop at error points?
Related Threads on C program help
  • Last Post
  • Last Post
  • Last Post
  • Last Post
14K
