Homework Help: C programming prime numbers
  1. May 25, 2010 #1
    Hello, i want to calculate and print prime numbers from 1 to 20. Ive provided my code below, and the program compiles but its just printing all numbers from 1 to 20, why?
    also have i used the continue statement correctly, since if it is found that a number is not prime then the next iteration starts in the for loop (ie all stuff below the continue statement is discarded).
    Thanks
    3. The attempt at a solution
    #include<stdio.h>
    main () {
    int x, i=2, y;
    printf("1\n2\n");
    for(x=3;x<21;x++) {
    i=2;
    while(i<x && y!=0) {
    y=x%i;
    i=i+1;
    if(y==0) continue;
    else printf("%d\n",x);
  3. May 25, 2010 #2
    Well you never reset i in the outer loop. In other words, i=2 the first time the inner loop runs, then i=3 and x=4, then i=4 and x=5, etc
  4. May 25, 2010 #3
    ok ive reset it, but its just prints 1 2 3
  5. May 25, 2010 #4
    DaveC426913
    Have you run through your code on paper? i.e. Make boxes labeled x, y, i and then walk through the code line by line? It will show you why y is not equaling 0.
  6. May 25, 2010 #5
    ah yes, starting when x =4 and i=2 then 4%2=2 but this should be zero according to what i want.
    Im not sure how to change this
  7. May 25, 2010 #6
    DaveC426913
    Question:
    You declare y as an int, then in your while loop you test if it's !=0. Can you do this in c? You have not assigned it a value. I guess, since it's an int, it is aujto-assigned zero?
  8. May 26, 2010 #7
    yes you can do that in c, also it isn't auto assigned to 0, since if it was then, it would only print 1 and 2, but its printing 1 2 and 3.
    The error is where y never becomes zero. like is said above i need to fix the condition for the while loop. eg: when x=4 and i=2 then 4%2=2 but this should be zero according to what i want.
    Im not sure how to change this.
  9. May 26, 2010 #8
    D H
    Staff Emeritus
    The error is in this statement: while(i<x && y!=0) { ... }
    You haven't set y before entering the loop. If y is zero the loop will never be entered.
    Learn to use a debugger.
  10. May 26, 2010 #9
    ok so i have:
    #include<stdio.h>
    main () {
    int x, i=2, y=1;
    printf("1\n2\n");
    for(x=3;x<21;x++) {
    i=2;
    y=x%i;
    i=i+1;
    if(y==0) continue;
  11. May 26, 2010 #10
    D H
    Staff Emeritus
    And does that do what you want? (No.)
    Don't just stab in the dark when programming (or solving problems, in general).
    Do you have a debugger? Do you know how to use it?
  12. May 26, 2010 #11
    D H
    Staff Emeritus
    Or, for that matter, you could execute this simple program by hand. Try it. Why doesn't your program print 5? (It only reports 1, 2, and 3 as primes.)
    BTW, one is not prime. It stands by itself.
  13. May 26, 2010 #12
    i know why it doesn't print 5 because y never becomes zero (zero remainder when when a number is a factor of another). Read the comments above before posting. I am not taking a stab in the dark, i know my problems as i have stated them and need help. If you want to post unhelpful comments then go elsewhere.
    Im a mathematician, and it is a matter of opinion whether 1 is prime or not. Some textbooks say 1 is prime, whilst others don't, depending on how you define a prime number.
    I dont want your help, ill just go elsewhere.
