C: String arithmetic
  1. Jan 13, 2016 #1
    Write a program (without using GMP library - https://gmplib.org) which performs arithmetic operations on large positive integers (addition, subtraction, multiplication and division). Maximum number of digits in one number is 100.
    Large number is the number that can't be represented by standard data types (long long, ...), and it is represented as a string.
    Then allow incrementing and decrementing of a string, and finding the smallest and the largest string in an array of n strings.
    2. The attempt at a solution
    How would you do incrementing, decrementing and comparing Bignum strings?
    Here is the addition:
    Code (Text):
        #include<stdio.h>
        #define MAX 100//max. number of digits
        typedefstruct
            int arr[MAX];//array for one number
        }NUMBER;
        void read(NUMBER *add_num)//read one number
            int i,digit=0;
            char ch[101];
            scanf("%s",ch);
            while(ch[digit])//number of digits
                digit++;
            for(i=0;i < MAX;i++)
                digit--;
                if(digit >=0)
                    add_num->arr[i]=ch[digit]-'0';//int to char
                else
                    add_num->arr[i]=0;
        void addition(NUMBER a,NUMBER b,NUMBER *add_res)//add two Bignum strings
            int carry=0;
            int i,temp;
                temp=a.arr[i]+b.arr[i]+carry;//sum
                add_res->arr[i]=temp %10;//resulting digit
                carry=temp /10;//store carry
        voidprint(NUMBER *add_num)//print result
            int i;
            for(i=MAX-1;add_num->arr[i]==0;i--);//skip the leading zeros
            for(;i>=0;i--)
                printf("%d",add_num->arr[i]);
        int main()
            NUMBER x,y,z;
            printf("enter two positive integers: \n");
            read(&x);
            read(&y);
            printf("addition result: ");
            addition(x,y,&z);
            print(&z);
            return0;
  3. Jan 13, 2016 #2
    mfb
    2017 Award
    Staff: Mentor
    Incrementing is just adding 1, and decrementing is subtracting 1 (or adding 9999.....99 and ignoring the overflow)
    How do you compare numbers like those by eye? The same can be done in code.
    Code (Text):
    35356959849283293
    35846625235464635
     4735939384293894
  4. Jan 13, 2016 #3
    Mark44
    Staff: Mentor
    There are a couple of missing spaces in your code, below.
    typedefstruct needs a space after typedef
    voidprint needs a space after void
Have something to add?
Draft saved Draft deleted
Similar Discussions: C: String arithmetic
  1. C++ strings help (Replies: 2)
  2. Strings in C (Replies: 6)
  3. Help with C++ strings (Replies: 3)
Loading...
