Homework Help: C++ Urgent help, compiling error, Assignment due in 1 hour!
  1. Apr 25, 2012 #1
    Well I have written my entire program for my assignment, but I cannot get it to compile without multiple instances of the same error: "expected primary-expression before ']' token. Can anybody see a mistake I am making? I would greatly appreciate your help, thank you!
    2. Relevant equations
    3. The attempt at a solution
    Here is my code:
    Code (Text):
    #include <iostream>
    #include <iomanip>
    using namespace std;
    class CreditAccount
    public:
        CreditAccount(char[],char[],char[],int,int,double,double);  //constructor
        void showAccount();
        void setAcctNum(char[]);
        void setName(char[], char[]);
        void setExpiration(int, int);
        void setLimit(double);
        void changeBalance(double); //method prototypes
    private:
        char accountNumber[20];
        char lastName[21];
        char firstName[21];
        int expMonth;
        int expYear;
        double creditLimit;
        double currentBal; // data members
    CreditAccount::CreditAccount(char temp_a1[], char temp_a2[], char temp_a3[], int temp_i1, int temp_i2, double temp_d1, double temp_d2)
        strcpy(accountNumber, temp_a1);
        strcpy(lastName, temp_a2);
        strcpy(firstName, temp_a3);
        expMonth = temp_i1;
        expYear  = temp_i2;
        creditLimit= temp_d1;
        currentBal = temp_d2;
    Method: showAccount
    Use: This method will display the information in a CreditAccount object via cout.
    Arguments: This method takes no arguments.
    Returns: Void, returns nothing.
    void CreditAccount::showAccount()
        cout<<fixed<<setprecision(2)
            <<"Account Number:  " << accountNumber <<endl<<endl
            <<"Expiration Date: " << expMonth <<"/"<<expYear<<endl<<endl
            <<"Name:            " << lastName <<","<<firstName<<endl<<endl
            <<"Credit Limit:    " <<"$"<< creditLimit<<endl<<endl
            <<"Current Balance: " <<"$"<< currentBal;
     Method: setAcctNum
     Use: This function will change the account number. No error checking is needed.
     Arguments: This method takes a character array.
     Returns: Nothing
    void CreditAccount::setAcctNum(char newAcctNum[])
        accountNumber[] = newAcctNum[];
     Method: setName
     Use: This function will change either the first name, last name, or both.  If the null string is passed for either argument, the corresponding data member will not be altered.
     Arguments: Takes two arguments, two character arrays for first and last name.
    void CreditAccount::setName(char newFirst[], char newLast[])
        if (newFirst[0] != '\0' && newLast[0] != '\0')
            firstName = newFirst[];
            lastName = newLast[];
        if (newFirst[0] != '\0')
            lastName= newLast[];
        if (newLast[0] != '\0')
            firstName= newFirst[];
        }       //check for null terminator
     Method: setExpiration
     Use: This function will change the expiration date for the account.
     Arguments: Takes two arguments, both are integers to store the data entered.
     Returns: Nothing.
    void CreditAccount::setExpiration(int newMonth, int newYear)
        if (newMonth <1 && newMonth >12)
            cout<<endl<<"Invalid entry.  The entered month value must be between 1 and 12.";
        if (newYear <=2012)
            cout<<"Invalid entry.  The enter year value must be greater than the year 2012.";
        if (newMonth >0 && newMonth <13)
            expMonth = newMonth;
        if (newYear > 2012)
            expYear = newYear;
        }  // check for validity
     Method: setLimit
     Use:  This function will change the credit limit for the account.
     Arguments: Takes a double, which is the value of the new credit limit.
     Returns: Nothing.
    void CreditAccount::setLimit(double newCreditLimit)
        if (newCreditLimit > 0.00)
            creditLimit= newCreditLimit;
        if (newCreditLimit <= 0.00)
            creditLimit = 500.00;
            cout<<endl<<"The credit limit value must be greater than $0.00.  Please re-enter a valid value.";
        } //check for validity
     Method: changeBalance
     Use: This function will update the balance for the account.
     Arguments: Takes a double, which stands for the change in account balance.
     Returns: Nothing, void.
    void CreditAccount::changeBalance(double balanceChange)
        currentBal = currentBal + balanceChange;
        if(currentBal<0)
            cout<<endl<<"An over-payment was made.  A credit has been added to your account.";
        if (currentBal > creditLimit)
            cout<<"You have exceeded your credit limit.  A $25.00 over-the-limit fee has been applied to your balance.";
            currentBal= currentBal - 25;
        }  // apply fee to balance, and display message to user
    int main()
        CreditAccount Account1 = CreditAccount("1234-9876-2468-1357", "K", "Joe", 7, 2013, 1500.00, 1130.77);
        CreditAccount Account2 = CreditAccount("3453-1232-6445-0014", "TA Last name", "Ta First name", 14, 2010, -1.00, 1234.50);
        //call show account on Account1 object to display info
        Account1.showAccount();
        //call setName on Account1 object to change the name
        Account1.setName("Joe", "K");
        //call showAccount again to re-display with new name
        //call setName again and change both names
        Account1.setName("J", "K");
        //call showAccount again to re-display with both new names
        //call set AcctNum() to change the account number
        Account1.setAcctNum("3312-2342-6786-2342");
        //call showAccount again to show the changed data
        //call setExpiration to change the date to another valid date
        Account1.setExpiration(9,2014);
        //call setExpiration to change the date to an invalid data
        Account1.setExpiration(4,2009);
        //call changeBalance 5 times to apply 3 purchases and 2 payments made on the account
        Account1.changeBalance(20.00);
        Account1.changeBalance(45.00);
        Account1.changeBalance(12.00);
        Account1.changeBalance(1700.00);
        Account1.changeBalance(1520.00);
        cout<<endl<<endl<<"Account 2: "<<endl;
        Account2.showAccount();
    cout << endl;
    system("pause");
    return 0;
  3. Apr 25, 2012 #2
    Mark44
    Staff: Mentor
    I found four lines that the compiler is probably complaining about. The compiler probably is also giving you information about the line number where it's finding a problem. You are not using arrays correctly. For example, an expression such as newAcctNum[] is not allowed in a statement. (It is allowed in a declaration, such as where you declare the formal parameters of a function.)
    Take a look at some examples in your textbook on working with arrays.
    Code (Text):
        [color="red"]accountNumber[] = newAcctNum[];[/color]
     Method: setName
            [color="red"]
            lastName = newLast[];[/color]
            [color="red"]lastName= newLast[];[/color]
            [color="red"]firstName= newFirst[];[/color]
