Caclculus question
  1. Jan 8, 2005 #1
    Calculus question...
    I had this on a test yesterday, and for some reason it seems like it was way too simple.
    A cone with a radius of 5 ft and height of 10 ft is being filled with water at a rate of 3 ft^3/min. Find the rate at which the height of the water is changing when the height is 7 ft.
    So I have V=1/3 B * H, with the base being 25 pi, and dv/dt being 3 ft^3/min.
    dv/dt=1/3(25 * pi * dh/dt)
    3=1/3(25 * pi * dh/dt)
    9=25 * pi * dh/dt
    9/(25pi)=dh/dt
    dh/dt=0.1146 ft/min
    Is this correct? This is what I got the first time I did the problem, but I remember writing down my answer as 1.14 ft/min because that was the answer I got the second time I did it. It seems too simple, especially because this was worth twice as many points as any other problems on the test.
  3. Jan 8, 2005 #2
    The volume of a cone is:
    v = 1/3 * pi * x^2 * y.
    v = 1/12 * pi * y^3
    dv/dt = 3 ft^3 / min.
    We want to find dy/dt when y = 7.
    dv/dt = 1/4* pi * y^2 * dy/dt
    Hence dy/dt = (4/ pi*y^2 ) * dv/dt
    When dv/dt = 3 and y = 7 gives
    12/ 49pi whuch is approx 0.08 ft^2 / min
    This may have been worth twice as much as the other problems because you had to use similar triangles to obtain x in terms of y. In this case,
    x / y = 1/2
    x = 1/2y.
  4. Jan 8, 2005 #3
    dextercioby
    [tex]V(t)=\frac{1}{3}\pi r^{2}(t)h(t) [/tex] (1)
    Diff.wrt to time:
    [tex] \frac{dV(t)}{dt}=\frac{\pi}{3}[2r(t)\frac{dr(t)}{dt}h(t)+r^{2}(t)\frac{dh(t)}{dt}] [/tex] (2)
    At the moment "t":
    [tex] h=7;\tan\alpha=1/2 \Rightarrow r=7\tan\alpha=3.5 [/tex](3)
    [tex] r=h\tan\alpha \Rightarrow \frac{dr(t)}{dt}=\frac{1}{2}\frac{dh(t)}{dt} [/tex](4)
    Plug (3) and (4) in (2) and find
    [tex] \frac{dV(t)}{dt}=\frac{\pi}{3}[2\cdot (3.5)\cdot 7\cdot\frac{1}{2}\frac{dh(t)}{dt}+(3.5)^{2}\frac{dh(t)}{dt}]\Rightarrow \frac{dh(t)}{dt}=\frac{3\frac{dV(t)}{dt}}{\pi[7\cdot (3.5)+(3.5)^{2}]}[/tex]
    [tex]=\frac{3\cdot 3}{\pi(24.5+12.25)}=\frac{9}{\pi\cdot 36.75}\sim 0.08ft.s^{-1} [/tex] (5)
    Daniel.
