Calc 1 Optimization
  • Thread starter Sheneron
Consider the part of the parabola y=1-x^2 from x=-1 to x=1. This curve fits snugly inside an isosceles triangle with base on the x-axis and one vertex on the y-axis. What is the smallest possible area of such a triangle?
[tex] A = \frac{1}{2}x y[/tex]
[tex] y = 1-x^2 [/tex]
so
[tex] A = \frac{1}{2}x(1-x^2)[/tex]
I solved that, took the derivative and set it equal to 0. That gave me an answer of x=sqrt(1/3), but I know that is wrong since it doesn't encompass the parabola curve. What is wrong with this?
Answers and Replies
y should be the point of the vertex not the equation of the parabola, try finding the gradient of the slopes at x=-1 and 1 and see where they cross.
Of which slopes, the parabolas?
Dick
26,263
619
Suppose the point of tangency is at x=a. Then you know the tangent line goes through the point (a,1-a^2) and has slope -2a, right? Work back from that and figure out where that tangent line intersects the x and y axes. Then find the area of the triangle as a function of a. Now minimize with respect to a. That's what Firepanda meant.
Ok here we go:
the slope is equal to rise over run so:
[tex]f'(a) = \frac{y-b}{x-a}[/tex]
where a and b are just arbitrary points.
[tex]f'(p) = -2p = \frac{y - (1-p^2)}{x-p}[/tex]
where p is some point. And f'(p) is the derivative of f at point p. We don't use x since x is already a unknown variable in our equation.
If we solve that for y we get:
[tex] y = -2p(x-p) + 1-p^2[/tex]
[tex] y = p^2 -2px +1[/tex]
This is our equation of some tangent line to the parabola at some point p.
Solve for the y intercept by setting y=0
[tex]0 = p^2 -2px +1[/tex]
[tex]x = \frac{p^2 +1}{2p}[/tex]
and we know the x intercept equals:
[tex] y = p^2 + 1 [/tex]
So back to our Area formula:
[tex]A(p) = \frac{1}{2}(\frac{p^2+1}{2p})(p^2+1)[/tex]
Take the derivative of that and set it equal to 0.
Solve for p and you will get an answer of
[tex]p=\sqrt{\frac{1}{3}}[/tex]
Plug that back into your x and y intercept equations to get the x and y values. Plug those x and y values back into the area equation to get an answer of about 1.5396.
Dick
26,263
619
Bravo! Well done! Except that I think you are forgetting the part of the triangle in the negative x region. Isn't the area of the triangle really x*y, not (1/2)*x*y? I.e. (1/2)*(2x)*y? Actually, I think you are right numerically. It's just that A(p) isn't what you said it is. Just a typo, I'm shure.
Related Threads on Calc 1 Optimization
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
