Calc AB Related Rates Problem
  • Thread starter pry_or
A container of constant volume contains a quantity of gas under pressure. At t=0, the pressure is 4 psi and the temperature is 15°C per minute. What is the rate of change of the pressure inside the container at time t=0?
[itex]\frac{P}{T}[/itex] = constant
Taking the derivative of both sides and then simplifying, I ended up with:
T[itex]\frac{dP}{dT}[/itex] - P[itex]\frac{dT}{dT}[/itex] = 0
So solving for dP/dt:
[itex]\frac{dP}{dt}[/itex] = [itex]\frac{P}{T}[/itex][itex]\frac{dT}{dt}[/itex]
This is where I get stuck. I know P = 4 psi and dT/dt = 15°C per minute, but I can't figure out how to determine T. Without knowing the actual value of the constant in the original formula, I don't see how it is possible. The wording of the temperature value in the problem sounds odd to me. The only thing I can think of is that the temperature should be assumed to be 0°C at t=0 and so dP/dt does not exist. Is this it, or am I missing some way to find T?
Answers and Replies
7,040
15°C per minute is not a temperature. It's the time rate of change of temperature. What is the exact wording of this problem?
That is the exact wording of the problem. That's why I said the wording was odd.
7,040
Whoever wrote the problem made a mistake. I would get some clarification from the instructor as to what the real problem is.
That's what I expected, thank you!
Related Threads on Calc AB Related Rates Problem
  • Last Post
  • Last Post
E
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
