Calc II
  1. Jan 15, 2007 #1
    Find the volume of the solid which is obtained by revolving the discs [tex](x - 1)^2 + y^2 \le 1[/tex]
    3. The attempt at a solution
    I say using cylinders would be easiest so,
    [tex]\int_a^b{2\pi r(x)h(x) dx} = \int_0^2{2\pi x\sqrt{1-(x-1)^2} dx}[/tex]
    Any hints on how to get started with this integral?
    Find the arclength of the curve [itex]y = e^x[/itex] with [itex]0 \le x \le ln 2[/itex]
    [tex]y' =e^x[/tex]
    so I need to solve
    [tex]\int_a^b{\sqrt{1+(y')^2}dx} = \int_0^{ln 2}{\sqrt{1+e^{2x}}dx}[/tex]
    Any hints?
  3. Jan 15, 2007 #2
    [tex]\int{\sqrt{1+e^{2x}}[/tex]
    this can be written as [tex]{1+e^{2x}}^(1/2)[/tex]
    then to integrate you add one to the power...etc
    does this help?
  4. Jan 15, 2007 #3
    wait that came up wrong i meant:
    this can be written as (1+e^(2x))^(1/2)
  5. Jan 16, 2007 #4
    I can't do what you said as it's a composite function...
    Any other ideas?
  6. Jan 17, 2007 #5
    Gib Z
    sara_87, when doing exponents longer than one character, uses { } instead of ( ). It seems you just forgot, since you did it the first time with the 2x :D
  7. Jan 17, 2007 #6
    Gib Z
    o, cscott, would It help If You had it in this form? (Hopefully you know integration by parts ).
    Make a u substitution
    [tex]u=e^{2x}[/tex]
    [tex]\frac{du}{dx}=2e^{2x}[/tex]
    Solve for dx
    [tex]dx=\frac {du}{2e^{2x}}=\frac{du}{2u}[/tex]
    Now you just need to do the rest.
    [tex]\int (u+1)^{\frac{1}{2}} 2u du[/tex]
    Have fun :D
  8. Jan 17, 2007 #7
    question 1)Not that I want to ruin your fun here, but by revolving discs do you mean a sphere? If I draw a graph of a revolving disc unless it's simply rotating about it's axis which gives a circle, wouldn't I end up with a sphere? in other words [tex]\frac{4}{3}\pi r^3[/tex]
  9. Jan 17, 2007 #8
    cristo
    Staff Emeritus
    You made a slight mistake; the integral is [tex]\int \frac{(u+1)^{\frac{1}{2}}}{2u} du[/tex]
  10. Jan 17, 2007 #9
    Sorry, it should say "revolve the disc defined by ___ around the y-axis" which I think calls for cylinders to make it easiest and wouldn't be a sphere.
  11. Jan 17, 2007 #10
    Oh you mean revovle a cyclinder around the y axis. I suggest you copy out the question again exactly as it is on paper, as your original question is a little misleading. I thought you meant spinning a circle through 360 degrees.
  12. Jan 17, 2007 #11
    Gib Z
    cristo- ty for spotting this, my brain seems to be farting alot recently...
    cscott- either way, I still think integration by parts helps
  13. Jan 18, 2007 #12
    The first question I'm assuming your talking about a toroidal. which is found from the curve y=e^x. You may want to look up toroidal volumes.
    Hint: you should end up with the second question integral, part 1 if you have done it correctly.
    i.e. [tex]\int_a^b{\sqrt{1+(y')^2}dx= \int_0^{ln 2}{\sqrt{1+e^{2x}}dx}[/tex]
    The second I can only say was too complicated for the level I'm at although once I saw how it was done I could follow the steps easilly enough(I asked Dr.E.P.A Bailey. A colleague to solve it basically) Otherwise known as cheating :smile:
    let [tex]u^2=1+e^{2x}[/tex] and then substitute.
    then put in the form of partial fractions.
    [tex] \frac {f(u)}{g(u)}[/tex]
    where f(u) and g(u) are polynomials.
    You should end up with this:-
    [tex]\int_0^{ln 2} 1+\frac {1}{2(u-1)}. \frac {-1}{2(u+1)}[/tex]
    from here it should be fairly straightforward if you express the answer in the form of natural logs.
    Hope that helps.
