Calculate convection movement.
  • Thread starter zoteman94
Calculating convection movement.
Is there a simple way of calculating the mass flow inside a torus as a result of a difference in temperature.
Asuming the torus is placed vertically and the heat source and sink placed in this way.
Thank you very much.
Cold side
( o )
Hot Side
Answers and Replies
256bits
1,270
If your torus is made of solid material there would be no mass flow, just heat flow via conduction.
sophiecentaur
4,800
How could that involve the "mass flow" in the OP?
256bits
1,270
Mass flow of what?
OP did not specify if the torus is hollow and filled with fluid and of what type.
Is it a thin or thick shell torus?
Is the shell an insulator or a conductor of heat?
Is the torus completely filled with a liquid fluid? or gaseous?
Is a percentage of the volume of a hollow torus liquid and the rest vapour?
if so, does the temperature of the liquid reach boiling.
If so, will the cooling surface result in condensation of the fluid.
Etc
I choose the simplest case possible cuz i am basically lazy.
sophiecentaur
4,800
It was the way I took it, from the start. It was the only way which could elicit any sensible response at all. I think you were just a bit scratchy about it, to be honest. Don't we actually expect some sloppily thought out questions on PF? Half the problem can be stating the question in the best way.
You say you are lazy. I am certainly too lazy to try to work out a solution to the problem the OP was getting at. Far too hard and with far too many variables. But there would be solutions out there somewhere.
256bits
1,270
Yes, Sophiecentaur. Analysis of a problem and determination of conditions under which certain variables are important and others can be neglected can be the most difficult part of the process.
If the OP defines his scenario with some more detail it would not hurt to do so.
Ok ok people, yes, it's a hollow torus. I didn't specify thickness or fluid inside because I was looking for a general answer, however if you have any data for specific cases (e.g. water fluid, air, anything or specific thickness or material of the torus (maybe an ideal heat insulator)) I would like it too.
Thanks again.
Well, I just want to know the maximum Carnot efficiency an hypothetical engine running on convective movement, so ideal conditions can be assumed.
Related Threads on Calculate convection movement.
  • Last Post
11K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
