Calculate Current and Torque
The rotor blades of a quadcopter are 10cm long. Given that the thrust force generated by each rotor is 1N (giving a total of 4N for 4 rotors), calculate the torque () on each rotor, and the current drawn (I) from a 10V battery, given the following:
  1. Density of air, a = 1 kg/m3.
  2. Shaft efficiency, Nsh = Psh/Pe , where Psh & Pe are the shaft power and electrical power, respectively, is 0.95.
  3. Rotor efficiency, N =P/ Pe , where P is the power generated by the rotor, is 0.8.
  4. The rotor blades are rotating at a speed of 6000 RPM.
(Hint: Use that actuator disk model to compute the power required by the rotor)
Ans: 8mN.m , I= 2A
P = I V
KE = 1/2 mv^2
F = mv
F = mv. Found velocity of the air exiting the propeller. Tired to use KE equation to find power but it doesn't match the answe.
Answers and Replies
scottdave
Insights Author
1,814
778
Where did you get F = mv ? Mass times velocity is momentum, not force. Can you show calculations that you made in your attempt at the solution?
Related Threads on Calculate Current and Torque
  • Last Post
  • Last Post
  • Last Post
10K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
15K
