Calculate lim n->inf (n^2/n!)
  1. Apr 20, 2015 #1
    calculate lim n->inf (n^2/n!)
    2. Relevant equations
    3. The attempt at a solution
    i just calculated, and i got inf as the ans...
    n^2/1X2X3...Xn
    n/1X2X3...X(n-1)
    1/[(1X2X3...)/n](1-1/n)
    when n->inf, it will go to inf
    am i correct? or there is something wrong?
  3. Apr 20, 2015 #2
    SammyS
    Staff Emeritus
    That is incorrect.
  4. Apr 20, 2015 #3
    what is wrong?
  5. Apr 20, 2015 #4
    Mark44
    Staff: Mentor
    Your answer is wrong. The limit is not infinity.
    The 2nd and 3rd lines above are OK but written ambiguously.
    According to the standard rules of precedence, n/1X2X3...X(n-1) = ##\frac n 1 2 \cdot 3 \cdot \dots (n - 1)##, which is probably not what you intended.
    The 3rd line would be interpreted as ##\frac 1 { \frac{1 \cdot 2 \cdot 3 \dots } n} (1 - 1/n)##. That's so convoluted that you probably misled yourself.
  6. Apr 20, 2015 #5
    why not
    n / [1X2X3...(n-1)]
  7. Apr 20, 2015 #6
    Mark44
    Staff: Mentor
    That would be fine, although at the calculus level, you should get out of the habit of writing X for multiplication. It's too easily confused as a variable.
    So what is ##\lim_{n \to \infty}\frac n {1 \cdot 2 \cdot 3 \cdot \dots (n - 1)}##?
  8. Apr 20, 2015 #7
    lim→∞ 1/ [ (1⋅2⋅3⋅⋅⋅/n)(1-1/n)] = 1/0 = inf ??
  9. Apr 20, 2015 #8
    Ray Vickson
    You tell us.
  10. Apr 20, 2015 #9
    Mark44
    Staff: Mentor
    @cloveryeah, here are some easier examples for you, to help you get your head around this stuff.
    ##\frac {3^2} {3!} = \frac 9 6 = 3/2##
    ##\frac {4^2} {4!} = \frac {16}{24} = 2/3##
    ##\frac {5^2} {5!} = ?##
    ##\frac {6^2} {6!} = ?##
    Do you see any sort of trend here?
  11. Apr 20, 2015 #10
    pasmith
    Consider: If [itex]n > 4[/itex] then [itex]n! = n(n-1) \times \cdots \times 1 > n(n-1)[/itex]. Thus [itex]0 < \frac{n^2}{n!} < \frac{n^2}{n(n-1)} < \frac43[/itex]. That tells you that the limit of [itex]\frac{n^2}{n!}[/itex], if it exists, must be finite. Unfortunately this bound on [itex]\frac1{n!}[/itex] is not sufficiently accurate for the squeeze theorem to assist, since [itex]\lim_{n \to \infty} \frac{n}{n-1} = 1[/itex].
    But how, for [itex]n > 5[/itex], could you modify the above argument so that the squeeze theorem will assist?
Have something to add?
Draft saved Draft deleted
