Calculate limits
  • Thread starter lep11
lep11
380
1. Calculate lim x->0 (xtanx/cos(2x)-1) without using L'Hospitals rule.
I am told that lim x->0 (sinx/x)=1
If I substitute 0 in it gets 0/0. I have tried several trig identities without luck.
Answers and Replies
arildno
Dearly Missed
10,025
135
Formulate the double-angle identity, and in particular, replace cos(2x)-1 with a suitable expression with a trig function with "x" in its argument, rather than "2x"
lep11
380
How about cos(2x)-1=-2(sinx)2?
ppham27
I'd also note that
[tex]
\lim_{x \rightarrow p} \frac{f(x)}{g(x)} = \frac{\lim_{x \rightarrow p} f(x)}{\lim_{x \rightarrow p} g(x)}.
[/tex]
Saitama
4,243
93
Correct. Write tan in terms of sin and cos.
arildno
Dearly Missed
10,025
135
An excellent choice of identity!
Use that in your example, and simplify your expression. Remember that 2cos(x)sin(x)=sin(2x) will be very handy indeed for further simplifications. (It is not strictly necessary to invoke)
arildno
Dearly Missed
10,025
135
I'd also note that
[tex]
[/tex]
In general, completely incorrect.
Try it on lim_infty x/x, for example.
ppham27
Sorry, I should clarify that it's true provided that limits of [itex]f[/itex] and [itex]g[/itex] exist at [itex]p[/itex] and the limit of [itex]g[/itex] at [itex]p[/itex] is nonzero.
arildno
Dearly Missed
10,025
135
Then we are in agreement. :smile:
lep11
380
hmm...xtanx/(cos(2x)-1)=xsinx/cosx/-2(sinx)2=xsinx/-2cosx(sinx)2=xsinx/-sinxsin(2x)
arildno
Dearly Missed
10,025
135
=-x/sin(2x)=-1/2*(2x/sin(2x))
Can you finish it off from here?
Saitama
4,243
93
hmm...xtanx/(cos(2x)-1)=xsinx/cosx/(-2sinx)2=xsinx/-2cosx(sinx)2=xsinx/-sinxsin(2x)
Why simplify to sin(2x)? Keep it simple.
Use the relevant equation you have posted.
arildno
Dearly Missed
10,025
135
I put him on that path; I believe my personal sense of aesthetics interfered with what is "simplest"
If OP does not use my hint there, he'll arrive at -1/(2cos(x))*(x/(sin(x)) which I personally find ugly, but which might, possibly, be regarded as objectively simpler.
lep11
380
Not sure :redface: It's still giving me trouble.
arildno
Dearly Missed
10,025
135
Well, if x goes to zero, then y=2x also goes to zero, doesn't it?
So, you could evaluate your limit as calculating:
-1/2*lim_y->0(y/sin(y))
lep11
380
lim x->0 (sinx/x)=1 and lim x->0 (x/sinx)=1???
arildno
Dearly Missed
10,025
135
That's right!
So, lim y->0 y/sin(y)=??
lep11
380
That's right!
=1... I was just unsure if lim y->0 y/sin(y)=1 thanks a lot
lep11
380
That's right!
=1 but why?
arildno
Dearly Missed
10,025
135
Note that with limits, the symbol used is NOT the important thing; rather, it is how that symbol (either "y" or "x" in this case) appears distributed in the formula that is important for the evaluation of the limit.
"2x" (i,e, "y") plays the same role in the limiting process as "x" does in your received formula.
Is there STILL a difference?
Sure, if we are nitpicky, and require that the "x" is in "2x" is the SAME "x" as in x/sin(x).
For each choice of "x", "2x" will have double the value of "x". Thus, if you look at a sequence of x's converging to 0, precisely the same sequence with "x" replaced by "2x" will, typically, be SLOWER in going towards zero than the single x will. (take the sequence of x's like 1/n, the 2x's go as 2/n, both go to 0 as n goes to infinity, but at different rates)
But, both the "x" and the "2x" will reach the same point in the end. It has no bearing on the actual limit value (THE end point of the limiting process!!), but a certain bearing on the "time" the limiting process takes.
ppham27
=1 but why?
Because
[tex]
\lim_{x \rightarrow 0}\frac{x}{\sin x} = \lim_{x \rightarrow 0}\frac{1}{\frac{\sin x}{x}} =
\frac{\lim_{x \rightarrow 0}1}{\lim_{x \rightarrow 0}\frac{\sin x}{x}} = \frac{1}{1} = 1.
[/tex]
Suggested for: Calculate limits
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
