Apost8
- 48
Probably not very accurate, I admit, but it might be fun to try:http://www.wikihow.com/Calculate-Pi-by-Throwing-Frozen-Hot-Dogs"
It goes back even farther than that:neutrino said:The process of throwing toothpicks across a ruled sheet of paper sounded familiar... that was from a problem in Griffith's QM text.
To calculate Pi with hotdogs, you will need to measure the circumference of a hotdog and divide it by its diameter. This will give you a value close to Pi (3.14).
Hotdogs are a convenient and accessible object for measuring Pi. They have a circular shape and are readily available in most grocery stores, making them a simple tool to use for this calculation.
The accuracy of the Pi calculation with hotdogs will depend on the precision of your measurements. The more precise your measurements are, the closer your calculation will be to the actual value of Pi.
Yes, you can use any type of hotdog as long as it has a circular shape. However, it is recommended to use the same type of hotdog for consistency in your measurements.
There is no specific method for measuring hotdogs to calculate Pi. You can use a ruler or measuring tape to measure the circumference and diameter, or you can use a string and then measure the length of the string. The important thing is to be consistent in your measurements.
