Calculate shaft for gears
  1. Oct 5, 2012 #1
    Already calculated:
    Tangential Forces :
    Pinion A=2850 N
    Gear B=2850 N
    Pinion C= 8550 N
    Gear D= 8550 N
    Radial Forces:
    Pinion A= 1000 N
    Gear B= 1000 N
    Pinion C= 9100 N
    Gear D= 9100 N
    Diameters:
    Pinion A= 60mm
    Gear B= 180mm
    Pinion C= 60mm
    Gear D= 200mm
    The distances between Gear B and Pinion C for the moment can be said to be X(mm). and the distance between the gears and bearings can be said to be Y(mm).
    2. Relevant equations
    Moment = F*d
    3. The attempt at a solution
    I've attached a picture of how the gears/shaft/bearings are arranged.
    My question is how do i calculate the shaft diameter(s)
    using the moment formula i know that i can calculate torque for each gear. It would just be the tangential force*the radius of the gear. I have no clue what to do with the radial loads or if I need to calculate any other forces.
    any help?
  3. Oct 5, 2012 #2
    just worked out the torque for each gear:
    Pinion A: 85.5 Nm
    Gear B: 256.5 Nm
    Pinion C: 256.5 Nm
    Gear D: 855 Nm
    not sure what to do with these...
  4. Oct 6, 2012 #3
    CWatters
Similar Discussions: Calculate shaft for gears
  1. Gear Shaft Design (Replies: 13)
  2. Gear shaft design (Replies: 3)
  3. Gears/shaft (Replies: 0)
Loading...
