fluidistic
- 261
I'm stuck in the following problem: In a particular solid-liquid phase transition the point ##T_0##, ##P_0## lies on the coexistence curve. The latent heat of vaporization at this point is ##l_0##. A nearby point on the existence curve has pressure ##P_0+p## and temperature ##T_0+t##; the local slope of the coexistence curve in the P-T plane is p/t. Assuming ##v##, ##c_p##, ##\alpha## and ##\kappa _T## to be known in each phase in the vicinty of the states of interest, find the latent heat at the point ##P_0+p##, ##T_0+t##.
##l=T_{\text{transition}}(s_{\text{liq.}}-s_{\text{sol.}})##. (1)
##c_p=\left ( \frac{\partial s}{\partial T} \right ) _P##
##\alpha = \frac{1}{v} \left ( \frac{\partial v}{\partial T} \right ) _P##
##\kappa _T =-\frac{1}{v} \left ( \frac{\partial v}{\partial P} \right )##
So I want to use equation (1). My idea is to expression the entropies of the liquid and solid phase as functions of alpha, kappa, etc.
So I've thought of s as a function of P and T to start with. I then took the total differential of s to reach ##ds=-\alpha v dP+c_p dT##. I've tried to make appear ##\kappa _T## without any success.
That's basically where I've been stuck for the last days, almost a week now. My friend told me to make a Taylor's expansion for the latent heat, so I've written down ##l(T) \approx l(T_0)+ l'(T_0)(T-T_0)## though I don't think that's correct since the latent heat depends on both the temperature and entropy; not the temperature alone.
So I'm looking for getting the ##\Delta s##. I've ran out of ideas, any tip is welcome.
