1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Calculate the pressure?
  1. Sep 26, 2016 #1
    Jane, a vet, is trying to sedate a dog by injecting him with sedative in a hypodermic syringe that
    has a needle 20mm long with internal diameter 0.4 mm. The vet wishes to inject the dog with
    3 ml of anaesthetic that has viscosity 4 x10^-3 Pas. Since the dog is struggling hard, she needs
    to get it into his bloodstream within 1 second.
    (a) How much pressure needs to be applied to the fluid in the syringe barrel to achieve this
    rate of flow through the needle?
    (b) Explain why this is pressure is not absolute, but is relative to atmospheric pressure.
    (c) If the barrel of the syringe is 10mm in diameter, what force does Jane need to apply to the
    plunger to achieve the needed flow rate
    2. Relevant equations
    Poiseullie or Bernouli
    3. The attempt at a solution
    Hi there, I'm stuck at this question. I don't know if I should use pensoulli's equation or bernoulis! Well the question did ask how much pressure, but idk how to tackle this question :( I'm seeking advise please
  3. Sep 26, 2016 #2
    Bystander
    2016 Award
    Are you looking for flow rate? Or, energy conservation? Which equation applies?
  4. Sep 26, 2016 #3
    Flow rate I think. But again it asked for pressure also so i don't know where to start with.
  5. Sep 26, 2016 #4
    Bystander
    2016 Award
    Which equation depends on ΔP?
  6. Sep 26, 2016 #5
    heres what I think, so Q is flow rate right? can we do 3ml/1= 3ml/s? then sub the value inside the it into the poiseulles equation?
  7. Sep 26, 2016 #6
    Bystander
    2016 Award
  8. Sep 26, 2016 #7
    is it actually?
  9. Sep 26, 2016 #8
    Bystander
    2016 Award
    It is; you'll have to convert/invert between CGS & MKS units (ml, Pa⋅s, mm, and so on).
  10. Sep 26, 2016 #9
    alright, so heres what I've done=
    delta p= 8*u*L.Q/pi*r^4
    where I got my Q as 3m/s
    I converted my Length into 0.02m
    R= 0.0004m
    Then i subbed the value inside equation as = 8.4x10^-3pa x 0.02m x 3m/s / pi x 0.0004^4= 2.38x10^10pa which looks weird!
  11. Sep 26, 2016 #10
    Bystander
    2016 Award
    That looks high to me; can you double check it?
  12. Sep 26, 2016 #11
    I did but still yeilds me the same, although I'm not sure about one thing.. for r i used "internal diamater 0.4mm" which i converted to meters?
  13. Sep 26, 2016 #12
    Bystander
    2016 Award
    Does radius equal diameter?
    Not 8.4 ... :H
    One milliliter is 10-6 m3.
  14. Sep 26, 2016 #13
    haha I didn't do 8.4 it was type mistake, also in regard to radius, we are not given how am I suppose to find it?
  15. Sep 26, 2016 #14
    Bystander
    2016 Award
    Half the diameter?
  16. Sep 26, 2016 #15
    Thanks mate, I gave you a life :) p.s if u had time check out my other question as well. Thanks
  17. Sep 26, 2016 #16
    like* haha
  18. Sep 26, 2016 #17
    Bystander
    2016 Award
    All nighter?
  19. Sep 26, 2016 #18
    Nein, im finished with my chem so im about to sleep haha
Have something to add?
Draft saved Draft deleted
Similar Discussions: Calculate the pressure?
  1. Pressure Calculation (Replies: 11)
  2. Calculate pressure (Replies: 5)
Loading...
