Calculate the Vout vs Vin characteristics for a diode circui
  • Thread starter mveep
  • Tags
    Diode
In summary, the voltage at Vout will be 5.7 V when the diode is conducting, and zero when the diode is not conducting.
mveep
Calculate the Vout vs Vin characteristics for input voltages of 5V to 10V peak.[/B]
Would Vout simply be nothing because the diodes are connected in anti-parallel?
Putting a volt probe at Vin and Vout gives something like: (Green is Vin, red is Vout)
Why is Vin not shown as a sine wave?
Hi mveep, Welcome to Physics Forums!
What do you think might be effect of the 5 V sources in series with the diodes? Isolate one of the diodes branches just to see how it behaves:
What potential would V1 have to reach for D1 to conduct (be forward biased)?
gneill said:
Hi mveep, Welcome to Physics Forums!What do you think might be effect of the 5 V sources in series with the diodes? Isolate one of the diodes branches just to see how it behaves:
Something higher than 5V? If there's no potential difference (if V1 is smaller than 5), the diode is off, correct?
Remember that the diode is not ideal here (it's a 1N4001) so it will have a forward bias voltage contribution, too. What's the typical forward voltage of a silicon diode?
0.7V
Right. So add that to the 5 V you stated in your previous answer. That gives 5.7 V. So you can expect the diode to turn on when the potential V1 reaches 5.7 V.
Now let's extend our view of the circuit slightly to include the power source and resistor:
If the diode forward voltage remains essentially constant so long as the diode is conducting (a pretty good approximation for this situation), what do you expect to happen to V1 for different values of Vin?
V1 would be 0 if Vin is 5V to 5.6V, but the same as Vin if Vin is higher than 5.7V
mveep said:
V1 would be 0 if Vin is 5V to 5.6V,...
Make that 5.7 V rather than 5.6 V. You said the forward voltage of the diode is 0.7 V.
mveep said:
...but the same as Vin if Vin is higher than 5.7V
How? Which one of the two voltages in the diode branch can change while the diode is conducting? Will the 5 V source change value? Will the 0.7 V diode forward voltage change?
Ok, so V1 = 0 for Vin less than 5.7V
The 0.7 forward voltage will change
No, if the diode is not conducting what's the current through the resistor?
No. It cannot. The forward voltage of a diode is (almost) constant.
If the diode isn't conducting, there would be no current through the resistor correct?
Correct. So what is the potential drop across it?
If there's no current, there's no potential drop right?
Correct again :smile:
So what does that make V1 (so long as the diode is not conducting)?
So V1 would be Vin?
mveep said:
So V1 would be Vin?
Yes! So V1 "follows" Vin until the diode conducts. Then it is held at 5 V + VD no matter how high Vin goes. That is, this branch limits the maximum voltage of V1 to 5.7 V.
Do a similar analysis for the other diode branch alone.
The voltage at V2 would always be Vin because the diode is in reverse saturation?
I don't think that "reverse saturation" is a valid term. Perhaps you mean cuttoff (not conducting)? That would be true if Vin could only take on positive values. What happens as Vin goes negative?
reverse bias and reverse saturation were the terms I learned in class
When Vin goes negative, it will add with the +5 source?
You can think of it that way if you're doing KVL around the loop. You should be able to find the conditions for Vin where the diode is cut off and when it is conducting, just as for the other branch.
The 2nd diode would be cut off when Vin is positive.
When Vin is negative:
The 2nd diode will be conducting from 0->-4.3V
It will be cut off at any value of Vin is less than -4.3
No. Think about it, the two circuits are essentially the same (Vin, 5 V, resistor, diode), the only difference being the diode branch is inverted. So the two should behave symmetrically.
With the diode reversed, it's forward voltage drop's direction is reversed in the branch, too. So it still "adds" to the 5 V (it's potential drop has the same direction as that of the 5 V source). Note the potential drop for the diode in the image below:
So this too (V2) would be Vin until -5.7V, and then capped at -5.7V?
Right.
gneill said:
Right.
What would Vout look like? Do you happen to have any idea why my PSpice generated graph is showing 0V for Vin?
That would depend on what Vin looks like and how much of Vin lies between the +/- 5.7 V clipping limits of the circuit.
Nope. Often that sort of issue is due to forgetting a connection or making an incorrect parameter setting. The scales on the graph in your first post look suspicious, being on the order of 10-180.
1. How do I calculate the Vout vs Vin characteristics for a diode circuit?
The Vout vs Vin characteristics for a diode circuit can be calculated by using Ohm's Law and the diode equation. First, determine the voltage drop across the diode by subtracting the forward voltage from the input voltage. Then, use Ohm's Law to calculate the output current. Finally, use the diode equation to calculate the output voltage. Repeat this process for different input voltages to create a Vout vs Vin graph.
2. What is the diode equation and how is it used to calculate Vout?
The diode equation is a mathematical relationship that describes the behavior of a diode. It states that the current through a diode is equal to the reverse saturation current multiplied by the exponential of the forward voltage divided by the thermal voltage. This equation can be rearranged to solve for Vout, which is the voltage across the diode.
3. Can I use a linear approximation to calculate the Vout vs Vin characteristics for a diode circuit?
No, a linear approximation cannot be used to accurately calculate the Vout vs Vin characteristics for a diode circuit. Diodes have a non-linear relationship between voltage and current, so a linear approximation would not accurately represent the behavior of the diode.
4. How does the input voltage affect the Vout vs Vin characteristics for a diode circuit?
The input voltage directly affects the Vout vs Vin characteristics for a diode circuit. As the input voltage increases, the voltage drop across the diode also increases, resulting in a higher output voltage. However, once the input voltage exceeds the forward voltage of the diode, the output voltage will remain constant.
5. What is the significance of the Vout vs Vin characteristics for a diode circuit?
The Vout vs Vin characteristics for a diode circuit provide important information about the behavior of the diode. They can be used to determine the voltage and current requirements for a specific application, as well as the maximum and minimum operating conditions for the diode. The characteristics also help in selecting the appropriate diode for a circuit and analyzing its performance.
  • Electrical Engineering
