Allura
- 23
Nvm, got it!
Nvm stands for Node Version Manager. It is a tool that allows you to easily switch between different versions of Node.js on your computer.
To check the current Nvm version, you can use the command "nvm --version" in your terminal or command prompt. This will display the current version of Nvm installed on your computer.
To update Nvm to the latest version, you can use the command "nvm install node" in your terminal or command prompt. This will install the latest version of Node.js and update Nvm to the latest version.
To switch between different versions of Node.js, you can use the command "nvm use
To uninstall Nvm, you can use the command "nvm uninstall
