What conversions are needed for solving a density equation?
  • Thread starter Makali
  • Tags
    Density
In summary, the student needs to solve for ρ1, the density of the aluminum block, when Al = 3.70 N but is 2.35 N submerged in water.
Makali
I need to solve the problem listed below. I do not need the answer. I just need to know if there's any conversions that are needed. Do I turn Newtons into kg and kg into g or...? Any kind of leads to help solve this problem would be greatly appreciated. Thank you.
(3.70 N)(1.00 g/cm3) / (3.70 N) – (2.35 g/cm3)
I am not very good with conversions.
First check to see if any of the units cancel (Numerator/Denominator) in your expression.
Whether or not you need to do conversions will depend upon how you want your density expressed. Do you want a result in g/cm3 or kg/cm3, or perhaps kg/m3?
Likes Makali
g/cm^3. The N will cancel in the numerator and denominator. 1 in the numerator can just be "thrown out". Since the numbers in the denominator are not multiplication, can we separate them to cancel with the numerator? so the answer that is left is -2.35 g/cm3 but can you have a negative density? Not sure if I am mathing correctly or not.
If you add or subtract quantities they must have the same units. So, you need to convert (N *g/cm^3 *1/N) to g/cm^3. You can look up the conversion factors (if any) in your textbook or on-line.
Note added in edit: the other responses did not appear on my screen until after I posted my reply. That type of thing happens to me a lot in this forum.
Likes Makali
Thank you!
Am I correct with my method stated above your comment, Mr Vickson? :)
Hang on, what are you taking to be the denominator? If I apply the standard parsing rules for mathematical expressions, there are two separate terms:
and
(2.35 g/cm3)
only one of which has a denominator. If that is not the case, then you should use parentheses to group terms to force the correct interpretation.
I can see the responses, but I cannot see the problem.
3.70 * 1 in the numerator is 3.70.. then the denominator is (3.70 N) - (2.35 g/cm3). The 3.70 N would both cancel due to division, correct? So the answer would be 2.35 g/cm3 but it's subtraction so would the answer then be -2.35 g/cm3? I am not sure if density can be negative or not. I'd assume it can't be.
The first term evaluates to 1 g/cm3, so you should throw it out entirely. You will still get a negative result for your density. That suggests that there is something wrong in the statement of the problem. Maybe if you explain how the expression (3.70 N)(1.00 g/cm3) / (3.70 N) – (2.35 g/cm3) came about, we can help you figure out what went wrong.
tnich said:
The first term evaluates to 1 g/cm3, so you should not throw it out entirely. You will still get a negative result for your density. That suggests that there is something wrong in the statement of the problem. Maybe if you explain how the expression (3.70 N)(1.00 g/cm3) / (3.70 N) – (2.35 g/cm3) came about, we can help you figure out what went wrong.
(Edited to add "not".)
The question is
Calculate the density ρ1 of the aluminum block using equation (3) in the lab manual:
The equation in the manual is p0 = W0 pf / Fb = W0pf / w0- T
Makali said:
The question is
That helps, but the problem statement is still incomplete. There is clearly more to it.
What aluminum block is the problem referring to?
We still need definitions of the variables in the equation. My guess is that p0 is the density of aluminum, pf is the density of water, W0 is the weight of the aluminum block and Fb is the weight of water displaced. I'm not sure if W0 and w0 are meant to be the same variable. I don't know what T is either.
Also, it is kind of difficult to estimate density of aluminum by its displacement of water since it is more dense than water and will sink to the bottom of the bucket. So unless you can tell us what the problem is you are trying to solve, we really can't do much to help you.
I ended up figuring it out. Thanks.
What is the formula for calculating density?
The formula for density is density = mass / volume.
How is density measured?
Density is typically measured in grams per cubic centimeter (g/cm3).
What is the importance of calculating density?
Calculating density allows scientists to determine the amount of mass in a given volume, which can provide valuable information about the properties of a substance.
How do you calculate density if the mass and volume are given in different units?
If the mass and volume are given in different units, they will need to be converted to the same unit before calculating density. For example, if the mass is given in kilograms and the volume is given in milliliters, the mass would need to be converted to grams and the volume to cubic centimeters before using the formula.
What are some real-world applications of calculating density?
Calculating density is important in many fields, such as chemistry, geology, and engineering. It is used to determine the purity of substances, identify unknown substances, and understand how materials will behave under different conditions.
  • Nuclear Engineering
