Calculating Empirical Formulae
  • Thread starter thomas49th
  • Tags
    Formulae
In summary, the conversation is about finding the empirical formula of magnesium nitride. The first step is to convert the mass of magnesium and nitrogen into moles and then find the ratio between them. The ratio of magnesium to nitrogen is 3:2, which means that 3 moles of magnesium reacts with 2 moles of nitrogen to form magnesium nitride. This information was helpful for the person asking the question, who had already completed their GCSE chemistry and was starting university the next day.
Hi. I am having problems with finding the empirical formulae
What is the emprical formula of magnesium nitride if 0.72g of magnesium combines with 0.28g nitrogen?
So what would my first step be? Find magesuim... which would be 0.44g?
Can you take me through the steps?
Thx
Thx
I would start by converting your Mg and N into moles. The basic idea is to look at the ratios of one substance to another to find the emiprical formula.
I don't know why you subtracted up there. Mass must be conserved, so if you start out with 0.72g and 0.28g, how much must you have after the reaction?
First calculate the number of moles of both of them by dividing each by their atomic weights.
Moles are obtained
Now divide each mole by the smallest mole obtained i.e. 0.02 mole of nitrogen, ratio obtained will be 1.5 of magnesium and 1 of nitrogen
as 1.5 is not a whole number multiply it by 2 to get a whole number and you will get as 3 and 2 respectivley. thus from this you can get that 3 moles of magnesium reacts with 2 moles of nitrogen to give magnesium nitride.
I hope this will help you out.
Regards
Hahaha thanks :D But a little late, I did my GCSE chemistry over 3 years ago and got my A - never said thank you hage567. Infact, I'm starting university tomorrow!
Thanks
Thomas :)
Hello,
Thank you for reaching out. I would be happy to assist you with calculating the empirical formula of magnesium nitride.
First, let's start by understanding what empirical formula means. An empirical formula is the simplest ratio of whole number subscripts in a compound. This means that we need to find the ratio of magnesium and nitrogen in the compound.
To start, we need to convert the given masses of magnesium and nitrogen into moles. We can do this by dividing the mass of each element by its respective molar mass. The molar mass of magnesium is 24.31 g/mol and the molar mass of nitrogen is 14.01 g/mol.
So, for magnesium, we have 0.72g/24.31 g/mol = 0.0296 mol. Similarly, for nitrogen, we have 0.28g/14.01 g/mol = 0.0199 mol.
Next, we need to find the smallest whole number ratio between these two values. To do this, we divide both values by the smaller one, which is 0.0199 mol in this case. This gives us a ratio of 0.0296 mol/0.0199 mol = 1.49. We can round this to the nearest whole number, which is 1.
This means that for every 1 mole of nitrogen, we have 1.49 moles of magnesium. To get whole numbers, we multiply both values by 2, giving us a ratio of 2 moles of nitrogen to 2.98 moles of magnesium.
Finally, we write the empirical formula using these whole number ratios. In this case, it would be Mg2N3.
I hope this helps guide you through the steps of calculating empirical formulae. Let me know if you have any further questions. Good luck!
1. What is the purpose of calculating empirical formulae?
The purpose of calculating empirical formulae is to determine the simplest whole number ratio of elements in a compound. This can provide important information about the composition and properties of a substance.
2. How is the empirical formula calculated?
The empirical formula is calculated by finding the molar mass of each element in a compound and converting it to moles. The moles are then divided by the smallest number of moles present to determine the ratio of elements. This ratio is then used to write the empirical formula.
3. Can the empirical formula be the same as the molecular formula?
Yes, the empirical formula can be the same as the molecular formula if the compound's molecular formula is already in its simplest form. However, in many cases, the molecular formula is a multiple of the empirical formula.
4. What information do I need to calculate the empirical formula?
To calculate the empirical formula, you need to know the mass of each element present in the compound and the compound's total mass. Alternatively, you can also use the percentage composition of each element to calculate the empirical formula.
5. How is the empirical formula used in chemistry?
The empirical formula is used to identify and classify compounds, determine their properties, and predict their chemical reactions. This information is essential in fields such as pharmaceuticals, materials science, and environmental science.
Suggested for: Calculating Empirical Formulae
