Calculating force of collison
  • Thread starter h9376w
h9376w
This isnt officially a homework question, just a problem/discussion that has arisen at work.....
so, basically we are looking to find out which would have a greater impact:-
a 1500kg vehicle travelling at a constant speed of 50mph
or
a 2000kg vehicle travelling at a constant speed of 30mph
we are basing this on impact with a stationary object with no movement, eg a solid wall.
Now i know that F = MA, but with the speed being constant then surely there would be no acceleration?
is there anyway we can calculate this with just the information provided? or does stopping time/distance have to get involved (as this is just a theoretical question, we havent actually got any of these factors)
Please Help :eek:
Answers and Replies
CAF123
88
Well, you could calculate the impulse (or change in momentum) of the cars assuming when they hit the wall, they stop. If you define positive x right, then the impulse will be in the negative x direction, same direction as the force exerted by the wall. To find the magnitude of the force exerted on the cars by the wall requires their time of contact.
h9376w
ok, so that would probably work.......
can you explain how i would go about working that out?
CAF123
88
Have you come across the concept of impulse and momentum?
Use the relation, [tex] Ft = m(v-u). [/tex] This is essentially F = ma but inputting a kinematic relation which describes constant acceleration. As I said before, with the given data you can only compute the quantity Ft, known as impulse.
See here : http://en.wikipedia.org/wiki/Impulse_(physics [Broken])
Suggested for: Calculating force of collison
  • Last Post
  • Last Post
