Calculating polar coordinates
B⃗ = -2.0ι^ + 3.0 j^.
Find the polar coordinates r and theta.
n/a
r=sqrt((-2.0)^2+(3.0^2))
r = 3.6
theta = tan^-1(3/-2) = -56 degrees
The answers seem to be wrong, can I get any guidance on this question please?
Answers and Replies
177
Draw a picture. Where is the Cartesian point? Why doesn't your angle make any sense?
Oh it's in the second quadrant, I see how the angle wouldn't work. So would it then be +56 degrees?
haruspex
Insights Author
7,385
Is that in the correct quadrant?
Do you know what the graph of tan looks like? If you put a horizontal line through it at a random height, what can you say about the intercepts?
I believe it is on the correct quadrant as -x,+y = quadrant 2. And there should only be one intercept I believe?? I'm confused
SteamKing
Staff Emeritus
12,798
1,670
Which quadrants have positive angles?
Where is zero degrees located?
How many degrees in each quadrant?
Quadrant I, and III have positive angles I believe There are 90 degrees in each quadrant, and zero is located on the x-axis on quadrant I.
SteamKing
Staff Emeritus
12,798
1,670
Well 2 out of 3 isn't bad, but it should be three out of three in this case.
If you start at zero degrees and go counterclockwise to 180 degrees, which quadrants have positive angles?
If you start at zero degrees and go clockwise to 180 degrees, which quadrants have negative angles?
The tricky thing about arctan on your calculator is it returns an angle θ such that -π/2 ≤ θ ≤ π/2, and the user is left with deciding in which quadrant the proper angle falls and its measure from zero degrees. That's why you should plot the original cartesian coordinates.
haruspex
Insights Author
7,385
Sure, but +56 degrees is not in that quadrant.
For the intercepts, what range of angles did you consider in saying there is only one intercept?
Quadrant I would be positive for the first part, and Quadrant IV would be negative on the second question.
So then what I would do is 180-54=124?
The answer -56 would be in quadrant IV and +56 would be in quadrant one then right?
SteamKing
Staff Emeritus
12,798
1,670
You're still guessing here. I don't know why you won't plot the original cartesian coordinates. That would answer your question directly.
It would be in quadrant II after I plot (-2,3). Would the angle I be measuring start from the x-axis from quadrant I though?
Never mind, I figured it out, I subtracted 180 with 56 = 124 degrees. Thanks.
Related Threads on Calculating polar coordinates
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
