Calculating Riemann Zeta function
In summary, to calculate \zeta(4) using the method of Euler, we substituted s=4 in the definition of the Riemann Zeta function and equated the coefficients of x^4 in the expanded series for \frac{\sin{x}}{x} and \zeta(4), which gave us the simplified equation \zeta(4)=\frac{1}{1^4}+\frac{1}{2^4}+\frac{1}{3^4}+\frac{1}{4^4}+\frac{1}{5^4}+\frac{1}{6^4}+... Then, using the formula for the sum of a geometric series, we arrived at the final solution
Bill Foster
338
Using method of Euler, calculate [tex]\zeta(4)[/tex], the Riemann Zeta function of 4th order.
[tex]\zeta(s)=\sum_{n=1}^\infty \frac{1}{n^s}[/tex]
Finding [tex]\zeta(2)[/tex]:
[tex]\zeta(2)=\sum_{n=1}^\infty \frac{1}{n^s}=\frac{1}{1^2}+\frac{1}{2^2}+\frac{1}{3^2}+\frac{1}{4^2}+\frac{1}{5^2}+\frac{1}{6^2}+...[/tex]
[tex]\sin{x}=x-\frac{1}{3!}x^3+\frac{1}{5!}x^5+...[/tex]
[tex]\frac{\sin{x}}{x}=1-\frac{1}{3!}x^2+\frac{1}{5!}x^4+...[/tex]
[tex]\frac{\sin{x}}{x}=\left(1-\left(\frac{x}{\pi}\right)^2\right)\left(1-\left(\frac{x}{2\pi}\right)^2\right)\left(1-\left(\frac{x}{3\pi}\right)^2\right)\left(1-\left(\frac{x}{4\pi}\right)^2\right)\left(1-\left(\frac{x}{5\pi}\right)^2\right)...[/tex]
From the above, the coefficients of [tex]x^2[/tex] are:
[tex]\frac{1}{\pi^2}+\frac{1}{2^2\pi^2}+\frac{1}{3^2\pi^2}+\frac{1}{4^2\pi^2}+\frac{1}{5^2\pi^2}+...[/tex]
Now equate these coefficients to [tex]x^2[/tex] in the sine function series:
[tex]\frac{1}{\pi^2}+\frac{1}{2^2\pi^2}+\frac{1}{3^2\pi^2}+\frac{1}{4^2\pi^2}+\frac{1}{5^2\pi^2}+...=\frac{1}{3!}[/tex]
[tex]\frac{1}{1}+\frac{1}{2^2}+\frac{1}{3^2}+\frac{1}{4^2}+\frac{1}{5^2}+...=\frac{\pi^2}{3!}[/tex]
[tex]\zeta(2)=\frac{\pi^2}{6}[/tex]
I get the following for the coefficients of [tex]x^4[/tex]:
[tex]\frac{1}{2^2\pi^4}+\frac{1}{3^2\pi^4}+\frac{1}{2^23^2\pi^4}+\frac{1}{4^2\pi^4}+\frac{1}{2^24^2\pi^4}+\frac{1}{3^24^2\pi^4}+...=\frac{1}{\pi^4}\left(\frac{1}{2^2}+\frac{1}{3^2}+\frac{1}{2^23^2}+\frac{1}{4^2}+\frac{1}{2^24^2}+\frac{1}{3^24^2}+...\right)[/tex]
The problem is, how do I get [tex]\zeta(4)=\frac{1}{1^4}+\frac{1}{2^4}+\frac{1}{3^4}+\frac{1}{4^4}+\frac{1}{5^4}+\frac{1}{6^4}+...[/tex] out of that sum?
To calculate \zeta(4) using the method of Euler, you can follow these steps:
1. Start with the definition of the Riemann Zeta function: \zeta(s)=\sum_{n=1}^\infty \frac{1}{n^s}
2. Substitute s=4 in the above equation to get: \zeta(4)=\sum_{n=1}^\infty \frac{1}{n^4}
3. Use the fact that \sin{x}=x-\frac{1}{3!}x^3+\frac{1}{5!}x^5+... and \frac{\sin{x}}{x}=1-\frac{1}{3!}x^2+\frac{1}{5!}x^4+... to expand the series for \frac{\sin{x}}{x}.
4. Equate the coefficients of x^4 in the expanded series for \frac{\sin{x}}{x} and \zeta(4).
5. Simplify the equation to get: \zeta(4)=\frac{1}{1^4}+\frac{1}{2^4}+\frac{1}{3^4}+\frac{1}{4^4}+\frac{1}{5^4}+\frac{1}{6^4}+...
6. Use the formula for the sum of a geometric series to simplify the above equation and get the final answer: \zeta(4)=\frac{\pi^4}{90}.
So, the final solution is \zeta(4)=\frac{\pi^4}{90}.
1. What is the Riemann Zeta function?
The Riemann Zeta function, denoted as ζ(x), is a mathematical function that is defined for all complex numbers except 1. It is used in number theory and has important connections to prime numbers. It was first introduced by mathematician Bernhard Riemann in the 19th century.
2. How is the Riemann Zeta function calculated?
The Riemann Zeta function can be calculated using the infinite series formula: ζ(x) = 1 + (1/2)^x + (1/3)^x + (1/4)^x + ... It can also be calculated using the Euler-Maclaurin formula or by using complex analysis techniques.
3. What is the significance of the Riemann Zeta function?
The Riemann Zeta function has important connections to prime numbers and the distribution of prime numbers. It is also used in other areas of mathematics such as physics, engineering, and statistics. It has also been a subject of significant research and has contributed to the development of other mathematical theories.
4. What are the applications of the Riemann Zeta function?
The Riemann Zeta function has various applications in mathematics and other fields. It is used in number theory to study the distribution of prime numbers and to prove theorems related to prime numbers. It is also used in physics, specifically in quantum mechanics and statistical mechanics. Other applications include signal processing, coding theory, and cryptography.
5. Are there any open problems related to the Riemann Zeta function?
Yes, there are several open problems related to the Riemann Zeta function. One of the most famous is the Riemann Hypothesis, which states that all non-trivial zeros of the Riemann Zeta function lie on the critical line Re(s) = 1/2. This remains unsolved and is one of the most important unsolved problems in mathematics. Other open problems include the Goldbach Conjecture and the Twin Prime Conjecture, both of which have connections to the Riemann Zeta function.
