How to Calculate Tension in Cable for Stopping a Moving Truck
In summary, you will need to calculate the tension in the cables based on the distance and time the truck decelerates.
DKTKD
Hello,
I'm having trouble trying to calculate the tension in a cable
when dealing with constant velocity and no acccel.
For example.
A block moving with constant velocity tied to a wire that is
connected to a fixed wall.
When the slack in the wire ends the blocks comes to
an immediate stop.
What is the tensions in the wire?
The only way I think i can answer this is if i make many other
time, distance, etc.. assumptions?
What do you think?
Thanks,
DK
In effect, you'll be getting an impulse applied to the block.
When the slack in the wire ends, the wire will be extended slightly.
This will do work on the wire.
And of course you willl do (the same amount of) work in stopping the block.
consider the acceleration required to stop the block moving from its initial velocity, from this you can claculate the force applied to it and hence the tension in the wire
You are not given enough information to determine the acceleration or force. You would need to know the time or distance in which the block decelerated from its initial speed to rest.
Hmmm. If you knew the time the impulse acted for, then: <F> = p/t.
If you knew the spring constant k and the extension (delta)x, then I think it's just F = T = k(delta)x.
But we don't, so my guess is...
The impulse supplied by the wire to the block will be equal and opposite to the original momentum p of the block. Force is the derivative of momentum, so is F = d(delta)p/dx useable here? I can't think of any other way of doing it.
EDIT: aaaarrrggghhh! dx... dammit! Surely there's not enough info here!
Hello All,
Thanks for your repsonses.
As El Hombre Invisible has stated, "aaaarrrggghhh! dx... dammit! Surely there's not enough info here!"
When I was working on this problem. I felt the same way.
For example for calculating the impulse force/forces you need the
as HallsofIvy mentioned.
How do you find this if you are starting from scratch. See my post on "Using physics to solve stunt challenge"
If you are assuming Worst case forces, the time to stop would be almost instance and the distance to stop would be almost zero.
Using these deltas would give you basicly infinite force.
Now you can make assumptions such as 1ms or 1ns. But where's the accuracy in that?
Also there is the approach of determining the wire extension (delta)x, to assist in determining distance to use F = d(delta)p/dx. However, you need the force acting on the cable to determine that?
Not to mentions that you are trying to resolve the forces so that you can determine what material and length of the wire that is required as not fail due to the forces.
I looked through all my physics books and online references. And this type of problem is never presented. Stopping distances and time and other that are necessary to solve the tension in the wire are usually provided but not explained as to where they originated.
I felt as if I had to make too many assumptions. Especially in regards to determining
tension on the wire.
What do you think?
Thanks again for your posts.
Is this an actual question you've been set? Could it be that you are supposed to state the tension in the wire as a function of some other variable? The problem here is that you state the block as coming to rest instantly. This just isn't feasible. There has to be some acceleration and this must take some time, however small, to reduce the velocity to zero.
Yes, El Hombre Invisible.
My questions is based on my trying to solve a larger problem set to me.
I posted it in the General Physics section title Using physics to solve stunt challenge"
While trying to solve it, I felt i was also posed with the cart before the horse.
Like you mentioned There has to be some acceleration and this must take some time"
I agree. But the only way i thought I could solve the force would be to find out the
elongation in the wire. The elongation would give me the time and distance of decceleration. Knowing the time and distance should help me find the force, but I cannot resolve the elongation without knowing the force exerted on the wire.
I'll try it again and set it up with solving simultaneous equations.
Thanks.. let me know it you have anyother thoughts.
I read your post, DKDT, in the other forum about your stunt problem and got a better idea of what you're trying to do.
Is this right?
You have a 4000 lb truck moving at 40 mph and you want to see if it will stop within 5 ft by the stretching of two steel cables, where both cables are 5/8" diameter and 1000 ft long.
If the above is correct, then you can equate the work done in stretching the two cables to the work done in overcoming the kinetic energy of the truck (by bringing it to a complete rest).
You have steel cables, 5/8" diameter, and 1000 ft long.
You were given Young's modulus for the steel cables.
[tex]A = \pi \left(\frac{5}{8}\right)^2/4 = 197.93\ mm^2[/tex]
[tex]A = 197.93*10^{-6}\ m^2[/tex]
[tex]l = 1000\ ft = 304.8\ m[/tex]
[tex]E = 210\ GPa = 210*10^9\ N/m2[/tex]
[tex]E = \frac{\sigma}{\epsilon}[/tex]
[tex]\sigma = \frac{T}{A}[/tex]
[tex]\epsilon = \frac{e}{l}[/tex]
giving,
[tex]T = \left(\frac{AE}{l}\right).e[/tex]
or,
[tex]T = k.e \mbox{ where } k = \left(\frac{AE}{l}\right)[/tex]
Substituting in values for A,E,l we get the spring constant for steel as,
[tex]k = \frac{197.93*10^{-6}*210*10^9}{304.8}[/tex]
[tex]k = 136.37\ kN/m[/tex]
[tex]M = 4000\ lb = 1814.4\ kg[/tex]
[tex]V = 40\ mph = 17.882\ m/s[/tex]
To overcome the kinetic energy in the car by bringing it to rest,
[tex]KE = \frac{1}{2}MV^2[/tex]
[tex]KE = \frac{1}{2}*1814.4*(17.882)^2[/tex]
[tex]KE = 290,091.65\ Nm[/tex]
Work done in stretching both steel cables,
[tex]WD = 2*\frac{1}{2}k.e^2[/tex]
[tex]WD = k.e^2[/tex]
Equating Work done in stretching the cables to loss of energy in stopping the truck,
[tex]WD = KE[/tex]
[tex]k.e^2 = \frac{1}{2}MV^2[/tex]
[tex]136.37*10^3*e^2 = 290,091.65[/tex]
[tex]e^2 = 2.12724[/tex]
[tex]e = 1.458\ m[/tex]
So, it looks like the truck is going to stop within 1.5m and 5 ft = 1.524 m
So, you're just going to make it!
1. How do you calculate tension in a cable?
To calculate tension in a cable, you need to know the weight of the object being supported by the cable, the length of the cable, and the angle of the cable. The formula for tension is T = (W * L) / sin(θ), where T is the tension, W is the weight, L is the length, and θ is the angle.
2. What is the importance of calculating tension in a cable?
Calculating tension in a cable is important because it helps ensure the cable is strong enough to support the weight of the object it is holding. It also helps prevent the cable from breaking or becoming overstretched, which could lead to accidents or damage.
3. What units are used to measure tension?
Tension is typically measured in units of force, such as newtons (N) or pounds (lbs). However, it can also be measured in units of weight, such as kilograms (kg) or pounds (lbs).
4. How does the angle of the cable affect tension?
The angle of the cable directly affects the tension because the higher the angle, the more horizontal force is needed to support the weight of the object. This means that as the angle increases, the tension in the cable also increases.
5. What are some factors that can affect tension in a cable?
Aside from weight, length, and angle, other factors that can affect tension in a cable include the material and thickness of the cable, the temperature, and the amount of tension already present in the cable (such as from wind or other external forces).
  • Mechanical Engineering
