Calculating the Third Maximum
A single slit is illuminated with a helium-neon laser whose wavelength is 633 nm. If the slit width is 2.2 x 10^-5 m, calculate the third maximum in degrees.
Relevant equations:
sinO = (m + 1/2)x(wavelength) / w
The attempt at a solution:
sinO = (3 + 1/2)x(633 x 10^-9 m) / (2.2 x 10^-5 m)
O = sin inverse0.100704545 m
O = 5.8 degrees
The third maximum is approx. 6 degrees.
Im not completely sure if this is correct.
Answers and Replies
252
It's correct. sinO = (m + 1/2)x(wavelength) / w is only approximate anyway. only
the minima can be calculated exactly with sinO = (m)x(wavelength) / w
Related Threads on Calculating the Third Maximum
  • Last Post
44K
