Calculating the work done
  • Thread starter brawler234
A box is moving at a constant velocity. 250N of applied force is acting on a box while 250N of friction is acting on it on the opposite direction. If the box travels 4 meters in the same direction as the applied force, how much work is done?
I know that work = force * displacement.
Is the force in the equation supposed to be the net force (which would make work 0J) or just the applied force in the same direction of motion (which would make work 1000J)?
[Moderator's note: Moved from a technical forum and thus no template.]
Answers and Replies
A.T.
2,135
The question should state which work is to be computed.
Hmm... so there is work done by the box pusher as well as work done by the friction of the floor?
A.T.
2,135
Yes, and there is the net work done on the box, which the sum of them.
Likes sophiecentaur
tech99
660
This is the standard situation for practical moving objects, like cars, boats and sledges.
The work done by the pusher is 250 x 4 = 1000 J. This energy is then transfered to heat resulting from friction.
In any case where the vehicle is not accelerating, the work done is entirely expended in heat.
You don't have to consider the force of reaction in this calculation.
sophiecentaur
4,616
Work done 'by' and 'on' is always problematical. I have difficulty about work done 'by' friction because I feel that friction is not a source of Energy. It's an intermediate Force in an Energy Transfer process and, when Work is done via a friction mechanism, there is Energy input and Energy output. The distance moved by an Effort Force may be the same as the distance moved by a Load Force but the two forces will not be the same so there is Energy deficit.
The difference in Energy is described using the term Efficiency. The question of 'who dunnit?' need not apply. Perhaps this is the problem; people have to look for an agency instead of just describing a process.
6,071
Why is this a problem? Work is defined as a transfer of energy so since friction transfers energy it does work. There is no implication that friction is the source of the energy transferred.
A.T.
2,135
There is nothing problematical if you stick to the definition, and don't philosophize so much.
The floor is doing negative work on the box via friction. The box is not doing any work on the static floor, indicating that all the energy taken from the box by the negative work is dissipated by friction.
sophiecentaur
4,616
That's where we must disagree. You have a loss mechanism that is supplying energy. Don't you see how that isn't straightforward.
But this is exactly the problem. I stick to the definition and I don't philosophise but I keep reading on PF and elsewhere that people do get confused. I am certain that this confusion because, for instance:
. . . which is of course quite correct. But there is a dissonance there which represents a hurdle, not, of course when you 'get it'; I am talking about people who don't get it.
I guess all I would really want is for the definition of Work to be used straight and the direction of energy flow noted, when necessary, without the by and on. Anyone who isn't aware of the problems that 'people' tend to have with the implied agency involved should just read the confusion that's found in many posts about the way friction works. It is a mechanism that both supplies energy and dissipates energy at the same time. Isn't that a potential source of confusion?
Walking and driving a car are both topics that appear regularly and the by and on question is always in there somewhere and gets in the way. That's basically my evidence that people need help with this.
A.T.
2,135
The definition of work involves a force applied over a distance. To apply that definition you have to specify which force (exerted by what on what) is meant.
6,071
I do see that it isn’t straightforward but if you use the correct terms then it helps. For instance here you say “a loss mechanism that is supplying energy”. I would say “a loss mechanism that is transferring energy”. Do you see how that helps? “Supplying” sounds like it is a source, but “transferring” makes no such implication.
Anyone who has purchased something using PayPal should be able to understand the idea of a mechanism that transfers a quantity with some loss without being a source.
collinsmark
1,236
[I deleted a comment I made in this space. Let me reword it a little, and I'll repost.]
collinsmark
1,236
[This is nearly identical to my original wording. Only very minor changes were made.]
Work and kinetic energy are ultimately relative*; they depend on the frame of reference (FoR).
*(Although this applies to Einstein's relativlity too, let's just stick to Galilean relativity for this problem.)
In this problem, assuming a FoR stationary with the ground, the dot product between the applied force and the block's displacement is positive, meaning the work is being done by the applied force, and that work is done on the force of friction.
But one could just as easily define a new FoR to be the same velocity as the block's velocity. In that case, no net work is being done on or by the block, because the block's displacement is zero (the block isn't moving). But the ground is moving. So here, since the ground's displacement is in the same direction as the force of friction (on the block), the work is done by the force of friction. And the work is ultimately done on the applied force (since the applied force is ultimately in the opposite direction as the ground's movement).
So it doesn't really matter what is, and what is not, considered an "energy source," but rather the important part is what one chooses as one's FoR. Once a FoR is chosen, one can determine "by" and "on" by the following:
  • If the dot product between the force and displacement is positive, the force does positive work; the work is done by the force. (If it helps to remember this, just remember, "if work was easy, they wouldn't call it 'work.'")
  • If the dot product between the force and displacement is negative, the force does negative work; the work is done on the force.
sophiecentaur
4,616
Yes. Personally, I like to use the word "transfer" but it is common for people to use or imply "supplying" - which is an 'agency' word. I guess it's something to do with the causal chain idea and a word like "supplying" implies a causal direction.
I just read post #3 again and it makes my point totally.
That post implies to me that @brawler234 is uneasy about the notion of two sources of the same energy. But that's not always a problem. When you pull a string, you do work on it and the string does work on the toy; there's no explicit loss in the system and that's inherently different from the use of friction when walking across mud because (choice of FOR again) although we 'know' the energy chain direction, it is not blindingly obvious that you have to include the vectors in order to know that happens with the energy. (Not an obvious thing for non-Physicists to do)
Don't get me wrong. I don't have a problem with this particular stuff but I am constantly recognising where other people seem to. And the reason they have the problem is that "friction" is a loaded word in English. Friction slows things down and it has no earthly business speeding things up. That idea looms all the time.
A.T.
2,135
But that's a misconception about friction, not about work.
collinsmark
1,236
It all depends on your chosen frame of reference (FoR). Think about what happens when you put a "stationary" block on a "moving" conveyor belt.
sophiecentaur
4,616
The English Language doesn't use frames of reference and nor does peoples' intuition. That sentence of mine explains why people have such problems with friction; it doesn't represent what I think personally. If all you need to do is use the phrase FoR to get things straight, how is it that work and friction are such popular topics of confused questions on PF?
Just stop anyone in the street and ask them what friction does. That is my point. It's not Physics, it's language.
sophiecentaur
4,616
Yes. That's true in the strict sense and I am by no means trying to argue against the Physics. My opinion is that it gives people more problems because of the language that is used.
Of course, anyone who can be dispassionate about the topic and go along with the formal approach won't have a problem. But, as I wrote above, there are many posts which indicated that there is a problem and it would be a help if the wording were modified in order to avoid the misdirection.
A.T.
2,135
There are many words in physics which also appear in common language, leading to naive misinterpretations: force, energy etc.
... it would be a help if the wording were modified in order to avoid the misdirection.
Good luck convincing physicists to rename all that.
sophiecentaur
4,616
rename all that.
Straw man, I'm afraid. All I want is to leave out the On and By adverbs. Isn't Science all about change?
A.T.
2,135
sophiecentaur
4,616
You already brought up Newton 3 so the same magnitude force is involved. The direction defines the flow of energy. Why is by and on involved necessarily - although it could be handy for convenience. All your statements on this topic assume that people have the same level of appreciation of the situation that you do. My point is that they don't. Perhaps they 'should' ?
Moreover, if you take a snapshot of just part of a power chain and an arbitrary FoR, the by and on is unknowable. Is the car clutch being a driver or a brake? Which direction does on or by apply to?
A.T.
2,135
The definition of work involves a force. If that force is exerted by A on B, then the work calculated using that force is the work done by A on B.
jbriggs444
2019 Award
8,905
3,644
It seems to me that the energy transferred by kinetic friction could be usefully divided into three piles:
1. The work done by friction on B. i.e. the frictional force of A on B multiplied by the incremental motion of B's contact surface in your chosen lab frame. This will often be negative and could be phrased as "mechanical energy drained from B by friction".
2. The work done by friction on A. i.e. the frictional force of B on A multiplied by the incremental motion of A's contact surface in your chosen lab frame. This will often be negative as well and could be phrased as "mechanical energy drained from A by friction".
3. The dissipated energy. i.e. the frictional force of either on the other multiplied by the relative motion of the surfaces. Pick any sign convention you like so that this comes out non-negative.
If you add up the three, the result should come to zero. Energy is conserved.
A.T.
2,135
Right, so you can compute 3. directly from 1. and 2. without the need to pick a sign.
Likes jbriggs444
Related Threads on Calculating the work done
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
