Calculating Torque?
  • Thread starter mawais15
mawais15
24
Calculating Torque??
i wonder how would i calculate the amount of torque required to give a rectangular piece of marble, an angular velocity of pi radians/second given the angular moment of inertia of that slab.
The bearing supports holds a coefficient of friction of 0.2 and the shaft diameter is 20mm. the angular moment of inertia of the slab about the rotation axis is 200 kg-m2. The distance between supports is 1 meter and the slab is in the center of the shaft.
Regards
Answers and Replies
tiny-tim
25,836
255
hi mawais15! :smile:
torque gives you angular acceleration (τ = Iα), not angular velocity …
once you find the angular acceleration, you can get the angular velocity using the standard constant acceleration equations :wink:
mawais15
24
how about incorporating the bearing friction to maintain the desired angular velocity?
tiny-tim
25,836
255
the friction with the bearings is a torque also, so you just subtract it from the applied torque
mawais15
24
but i the question is that how much torque do i have to apply..
Suggested for: Calculating Torque?
  • Last Post
55K
  • Last Post
  • Last Post
28K
  • Last Post
  • Last Post
19K
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
