Homework Help: Calculating total charge
  1. May 18, 2010 #1
    The current at the terminals of the element in an ideal basic circuit element is
    i = 0, t < 0;
    i = 20e(-5000t) A, t [tex]\leq[/tex] 0
    Calculate the total charge ( in microcoulombs) entering the element at its upper terminal.
    2. Relevant equations
    3. The attempt at a solution I'm just starting a Circuit Analysis course next week and I'm looking ahead in the text, trying to hit the ground running. There are no sample problems that even give me a starting place??
  3. May 18, 2010 #2
    rock.freak667
    Current can be expressed at the rate of flow of charge, so that i =dQ/dt.
    So you can integrate over time and get the total charge. Though why it time t < 0?
  4. May 18, 2010 #3
    I suppose that is just a way of saying that there was no current flowing before the reference time, t = 0.
  5. May 18, 2010 #4
    I tried integrating and came up with -0.04e-5000t + C coulombs.
    Answer is supposed to be 4000 microcoulombs. My integration is a little rusty. Help?
  6. May 19, 2010 #5
    rock.freak667
    The -0.04 should be 0.004, but remember your time is t≥0. So you are really integrating from 0 to ∞ so you need to compute
    [tex]\left[ -0.004e^{-5000t} \right]_0 ^{\infty}[/tex]
  7. May 19, 2010 #6
    Thanks for the help, I knew the Integral to be solved and the limits of integration, what I was missing was the negative exponent of e. You helped me, thank you.
  8. May 19, 2010 #7
    Thanks rock.freak, I was overlooking the negative exponent of "e" when I was integrating.
    You helped me, thanks. Sometimes you just need to bounce it off someone else.
