Calculating Tractive Force
  1. Sep 29, 2009 #1
    Is the formula for tractive force = wheel torque/tyre radius, or wheel torque x tyre radius?
  3. Sep 29, 2009 #2
    T = F x D
  4. Sep 30, 2009 #3
    Basically, do you simply take the diameter of the crown wheel and tyre, then proceed to calculate the ratio between the two; therefore giving a reduction in torque?
  5. Sep 30, 2009 #4
    Torque = Force x Distance.
    (What I wrote above was kind of ambiguous, sorry)
    Rearranging for force gives torque / distance.
    So in this case it's wheel torque / the rolling radius (from cenre of wheel to outer egde of tyre).
    The wheel torque is the torque from the engine * the drive ratios of geabox * final dive ratio.
  6. Sep 30, 2009 #5
    Ranger Mike
    see post below in gen pyshics forumn..
    Wider tire giving better traction debate! Old Aug15-09, 04:19 AM
    also..you must measure radius of the tire..with mounted on the car, with full fuel, driver...
    because it will change from free state
    thing 2?? are you going straight or plan on turning at speed..see several posts on centifugal force, tire contact, tire friction etc..
Similar Threads - Calculating Tractive Force Date
Calculation of leakage from a sealed room Mar 14, 2018
Pulley/shaft calculation Mar 8, 2018
How to calculate the weight of a gear? Mar 6, 2018
Calculating Tractive Effort At Speeds Mar 5, 2015
Calculating starting/tractive force Jun 23, 2011
