• Support PF! Buy your school textbooks, materials and every day products Here!
Calculating work done
A carpenter is holding two tool boxes of mass 19kg and 21kg respectively. Calculate the work done to carry the tool boxes through a horizontal distance of 16m.
W = mgh
m = 21kg + 19kg
g = 9.81ms^-2
h = 0
W = (21 + 19)(9.81)(0)
W = 0J
Is this correct? And if this is correct, would you explain why it is 0J?
Answers and Replies
NascentOxygen
Staff Emeritus
1,072
The formula for work involves the dot product of two vectors.
W = F . s
Does this give you a hint?
(Yes, your answer of 0J is correct.)
HallsofIvy
41,833
955
In order to do work, you must move an object with mass in the direction of a force vector.
So if I use W = F . s, then it would be
W = (19 + 21)(9.81)(16) ?
Or is it,
W = (19 + 21)(9.81)(16) cos 90 ?
NascentOxygen
Staff Emeritus
1,072
Or is it,
this ^^^
Instead of writing the vector formula, it is often expressed as W = F s cosθ
and that's probably the best one to memorise.
NascentOxygen, would you tell me why the angle is 90? Shouldnt it be 0? And how about if I use sin 0? I will still get 0J.
NascentOxygen
Staff Emeritus
1,072
The question just tests how easily confused you are.
The only force mentioned is weight, and it acts downwards ⇓
while the motion described is horizontal ⇒
and the angle between those two vector quantities is ..... ?
You want to invent your own formula using sin 0° ? What angle in this picture is 0°?
Related Threads on Calculating work done
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
