Calculation of Scissors Lift
  • Thread starter nabilishes
nabilishes
I need help in calculating the forces that act upon the arms of a scissors lift. Attached is the force diagramm and some calculations i made earlier. The calculation was made based on each arm
It would be nice if any of you could have a look and check whether the calculation are correct or perhaps i missed something out.
Thankss
solutions are in the attached picture
Answers and Replies
nvn
2,128
32
nabilishes: It seems you are assuming Fa, Fb, Fc, and Fd are axial forces in members 1 and 2, which is incorrect. You would need to quit making that assumption, and rewrite your solution. Also, you did not give the dimensions of each arm segment. Also, you can solve for M in terms of F and alpha.
nabilishes
For M and F, i already know how to solve that. If i'm not wrong
M=(F+(Warm/2)) / tan alpha
Say L= 0.5 m
i need to calculate the stress acting upon the pivot and the moving points C and A.
C and A is bolted to a slot, where when the mechanical actuator or hydraulic cylinder acts upon C, the scissors lift will the object. Attached is a picture of the slot
So how do i get the force acting on both points?
nvn
2,128
32
nabilishes: OK, do what is mentioned in the first two sentences of post 2. And also use your expression for M in post 3, which is correct. However, I prefer to define, W = self weight of each arm, in which case, M = (F + W)/tan(alpha). Show your work, and someone might check your math.
nabilishes
I made some additional reading at stumbled upon the principle of virtual work and came to a conclusion that there sum of the work done by the pivot is zero since both forces have the same magnitude but opposite in sign.
Thanks for the help.
Suggested for: Calculation of Scissors Lift
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
