How to solve these calculus problems using substitution and the gamma function
  • Thread starter Thread starter Askhwhelp
    Calculus Integral
The discussion focuses on solving two integrals using the gamma function and substitution techniques. The first integral, from 0 to infinity of (y^b * e^(-y/2) dy), can be approached using u-substitution, leading to the result of 2^(b+1) * Γ(b+1), although there is confusion about the professor's answer being 1. The second integral, from 0 to infinity of (e^(-y^2/2) dy), is identified as a Gaussian integral, which requires a different approach, often involving the substitution u = y^2/2. Participants highlight that familiarity with Gaussian integrals can simplify the process, and the reflection identity for the gamma function is mentioned as a useful tool. The conversation emphasizes the importance of understanding these concepts for solving the integrals effectively.
Askhwhelp
I forgot to do these...long time ago
1) What is integral from 0 to infinity of (y^b * e^(-y/2) dy)?
2) what is the integral from 0 to infinity of (e^(-y^2/2) dy)?
Please show me the process to get to the answer please
How to use definition of gramma function to solve these?
It's a gamma function. If it were long ago and b were a small integer then you would work it out using substitution and integration by parts. I think you are supposed to use the definition of the gamma function.
And that's a gaussian integral. It's not considered an elementary integral either. What you learned a long time ago won't help. Isn't your course providing you with any clues?
'gamma' not 'gramma'. And what's the definition of the gamma function? Showing the definition might help you to get started. It won't help for the second one, that's different. Look up 'gaussian integrals'.
For question 1, I use u substitution, u = y/2 so du = 1/2 dy...so integral from 0 to infinity of ((2u)^b*e^-u du) <=> 2^(b+1) * integral from 0 to infinity of (u^b*e^-u du) <=> 2^(b+1) * integral from 0 to infinity (u^((b+1)-1)*e^-u du) <=> 2^(b+1) * gamma symbol which looks like F(b+1)=2^(b+1)* b!
However, the answer my professor gave is 1. I am wondering how could that be?
Don't know. That the integral is ##2^{b+1} \Gamma(b+1)## is right. I don't think that's 1.
For question 2, the answer I found is 1/(2*(sqrt(pi))*Γ(1/2).How to find Γ(1/2)?
Are you aware of the reflection identity \Gamma(z)\Gamma(1-z)=\frac{\pi}{sin(\pi z)}?
Likes 1 person
Does anyone find a earlier way to do the question?
I don't see an easier way to do the second question than letting u=\frac{y^2}{2} and solving for dy (which is what I imagine you did) unless you are already familiar with Gaussian integrals.
Edit: I'm not getting what you got. With the substitutions I mentioned, the integral becomes
\frac{1}{\sqrt{2}}\int_0^\infty e^{-u}u^{-1/2}du=\frac{\Gamma(1/2)}{\sqrt{2}}
As HS-Scientist just said, you don't have to go through the gamma function if you know a simple gaussian integral and use a substitution. And the gaussian you can get in a pretty simple way if you look it up.
