• Support PF! Buy your school textbooks, materials and every day products Here!
Calorimetry question
a laboratory technician adds 43.1 mL of concentrated, 11.6 mol/L hydrochloric acid to water to form 500 ml of dilute solution. the temperature of the solution changes from 19.2C to 21.8C. calculate the molar enthalpy of the equation.
so this is what is given
t=temperature (19.2-21.8= -2.6)
c=specific heat capacity. for water is 4.18 but i dont know if im suppose water for this
m=mass i'm a bit lost in this one but i used 43.1ml
/\H=mc/\t/n
this is what i tried
mHCl=43.1g t= -2.6 MHCl= 36.46 g/mol
43.1/36.46=1.18n mol
(43.1*4.18*-2.6)/ 1.182
=150.2
and i think the answer i got is wrong
Answers and Replies
For your change in temperature remember that it is the final temperature minus the initial temperature. You've shown the reverse. If the problem doesn't give you any information about the specific heat of the solution then it is probably safe to use 4.18 J/g-C. In reality, the specific heat of this solution would be slightly different. Mass is measured in grams...you are using milliliters. To find the mass of the solution, use the density of water (again, another assumption...assume density of solution is equal to that of water- 1.0g/mL unless otherwise stated).
umm yea i know to convert mL to gram. I still believe im getting the wrong answer. i dunno whats up with the mass but im thinking its not 43.1. im so lost now :(
does anyone know how to do this question? im praying to god that there was a mistake in my chemistry book
GCT
1,728
/\H=mc/\t/n
=150.2
It's too bad that they don't give you the initial temperature of the HCl solution, but for the sake of solving the problem with respect how your instructor probably wants you to do it, we should neglect this important aspect of calculating the molar enthalpy
You need to use the 500 mL to calculate the mass of water
Use this to calculate "q"
Find the moles of HCl and divide the "q" by this value
Arrive at the final units of J of KJ / moles HCl
Gokul43201
Staff Emeritus
/\H=mc/\t/n
m is the mass of the entire solution (assuming, as GCT pointed out, that the HCL is added at a temperature close to 19.2C). So that's the mass of about 543mL of liquid at a density of close to 1gm/mL.
GCT
1,728
The problem mentions "500 ml of dilute solution"; that is, 500 mL is the final volume right, unless I'm missing something here?
Gokul43201
Staff Emeritus
No, you're right. I didn't read carefully. The mass involved is that of 500mL of solution.
Related Threads on Calorimetry question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
