Calorimetry: Calculate Molar Enthalpy of Neutralization for Sulfuric Acid
  • Thread starter Physics197
  • Tags
    Calorimetry
In summary, to solve the problem of finding the molar enthalpy of neutralization for sulphuric acid, we can use the equations q=nH and q=mc(delta)T. By calculating the number of moles involved in the reaction and the heat released by the reaction, we can determine the molar enthalpy of neutralization for sulphuric acid.
Physics197
73
A student mixed 200.00ml of 1.5mol/L sulphuric acid with 400.00ml of 1.5mol/L sodium hydroxide. Both solutions were at 19.67 degrees celsius initially and the highest temperature reached by the reaction mixture was 34.06 degrees celsius. Calculate the molar enthalpy of neutralization for sulphuric acid.
q=nH
q=mc(delta)T
Just need help with starting how to solve this problem.
Hello, to solve this problem, we can use the equation q=nH, where q is the heat released or absorbed by the reaction, n is the number of moles involved in the reaction, and H is the molar enthalpy of neutralization. To find n, we can use the equation n=cV, where c is the concentration and V is the volume. We know the concentrations of both solutions and their volumes, so we can calculate the number of moles for both sulphuric acid and sodium hydroxide.
Next, we need to calculate the heat released by the reaction using the equation q=mc(delta)T, where m is the mass of the solution, c is the specific heat capacity of the solution, and (delta)T is the change in temperature. We know the initial and final temperatures of the reaction mixture, so we can calculate the change in temperature.
Once we have the heat released by the reaction, we can use the equation q=nH to solve for H, the molar enthalpy of neutralization. This will give us the energy released per mole of sulphuric acid involved in the reaction.
I hope this helps you get started on solving the problem. Let me know if you have any further questions. Good luck!
To calculate the molar enthalpy of neutralization for sulfuric acid, we first need to understand the concept of calorimetry. Calorimetry is the measurement of heat transfer in a chemical reaction. In this case, we can use the formula q=nH, where q is the heat transfer, n is the number of moles of the substance, and H is the molar enthalpy of the reaction.
To start solving this problem, we need to first determine the number of moles of sulfuric acid and sodium hydroxide that were used in the reaction. We can do this by using the formula n=CV, where C is the molar concentration of the solution and V is the volume in liters.
For sulfuric acid:
n = (1.5 mol/L) x (0.2 L) = 0.3 moles
For sodium hydroxide:
n = (1.5 mol/L) x (0.4 L) = 0.6 moles
Next, we need to calculate the heat transfer (q) in the reaction. We can use the formula q=mc(delta)T, where m is the mass of the solution, c is the specific heat capacity of the solution, and (delta)T is the change in temperature.
For sulfuric acid:
q = (0.2 kg) x (4.18 J/g*C) x (34.06-19.67) = 1217.2 J
q = (0.4 kg) x (4.18 J/g*C) x (34.06-19.67) = 2434.4 J
Now, we can use the formula q=nH to solve for the molar enthalpy of neutralization (H). Since the heat transfer is the same for both solutions, we can set up an equation:
(0.3 moles)(H) = 1217.2 J
(0.6 moles)(H) = 2434.4 J
Solving for H, we get:
H = 4057.3 J/mol
Therefore, the molar enthalpy of neutralization for sulfuric acid is 4057.3 J/mol.
1. What is calorimetry?
Calorimetry is the scientific method of measuring heat transfer in a chemical reaction or process. It involves using a calorimeter, a device that measures the change in temperature of a substance, to determine the amount of heat released or absorbed during a reaction.
2. How is molar enthalpy of neutralization calculated?
The molar enthalpy of neutralization for sulfuric acid can be calculated by dividing the amount of heat released or absorbed during the neutralization reaction by the number of moles of sulfuric acid used. This can be determined by using the formula Q/n, where Q is the heat change and n is the number of moles of sulfuric acid.
3. Why is sulfuric acid commonly used in calorimetry experiments?
Sulfuric acid is commonly used in calorimetry experiments because it is a strong acid that has a high heat of neutralization. This means that it releases a large amount of heat when it reacts with a base, making it ideal for studying heat transfer in chemical reactions.
4. What other factors can affect the accuracy of calculating molar enthalpy of neutralization?
Other factors that can affect the accuracy of calculating molar enthalpy of neutralization include experimental errors, such as heat loss to the surroundings, incomplete mixing of reactants, and incomplete reaction. It is important to control these factors as much as possible to obtain accurate results.
5. How is the molar enthalpy of neutralization used in practical applications?
The molar enthalpy of neutralization is used in practical applications, such as in the production of fertilizers, where sulfuric acid is used to neutralize alkaline soils. It is also used in the production of batteries, where sulfuric acid is used in the electrolyte solution to facilitate the transfer of charge. Additionally, it is used in the production of various chemicals and in the study of chemical reactions and thermodynamics.
